Here's the detail of my bikes:
03 Cg125
Model: 2003
Category: Road Bike .
Engine
Engine type: Single cylinder 4 Stroke
Bore and Stroke: 56.5 x 49.5mm
Compression ratio: 9:1
Displacement 124cc
Spark Plug: HERO DP8EA-9
Ignition system: Electrical CDI system
Final Drive: Chain
Starting: Kick Start
Battery: 12 V-2.5 AH
Fuse 10A
Chasis and Suspension
Trail: 80mm
Front tire: 2.50-18-4PR
Rear tire: 3.00-17-6PR
Power Transmission
Primary reduction: 4.0555
Final reduction: 20-.533
Dry Weight: 96.5 Kg
Engine Oil: 1 liters
Fuel tank: 11 liters Reserve: 2 Liters
Length: 1.900mm
Width: 730mm
Height: 1.020mm
Wheel Base: 1.200mm
91FZR250R
Engine Type: 249 cc, 4 Stroke, Liquid Cooled - Inline-4
Engine Bore and Stroke: 48 mm x 34.5 mm
Compression Ratio: 12:1
Valves DOHC, 4 valves/cylinder
Ignition System: Electronic
Claimed Horsepower: 45 hp (33.6 kW) @ 16000 rpm
Maximum Torque: 24.5 Nm (18.1 ft. lbs) @ 12000 rpm
Type of Lubrication: Wet sump 321.8lbs dry
Tires: 100/80-17 front, 130/70-18 rear
Transmission type: 6 speed
Final Drive: Chain
Starting: Electronic
...........General information.............
Model: Yamaha FZR 250
Year: 1991
Category: Sport
.........Engine and transmission.........
Displacement: 249.00 ccm
Engine type: In-line four
Stroke: 4
Power: 45.00 HP (32.8 kW)) @ 14500 RPM
Torque: 25.00 Nm (2.5 kgf-m or 18.4 ft.lbs) @ 11500 RPM
Max RPM: 18000
Compression: 12.0:1
Bore x stroke: 48.0 x 34.5 mm (1.9 x 1.4 inches)
Fuel system: Carburettor. MIKUNI BDS26
Valves per cylinder: 4
Fuel control: DOHC
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
Transmission type final drive: Chain
Clutch: Wet plate
...............Physical measures.............
Dry weight: 141.0 kg (310.9 pounds)
Seat height: 750 mm (29.5 inches) If adjustable, lowest setting.
Overall height: 1,120 mm (44.1 inches)
Overall length: 2,010 mm (79.1 inches)
Overall width: 680 mm (26.8 inches)
Ground clearance: 135 mm (5.3 inches)
Wheelbase: 1,375 mm (54.1 inches)
.........Chassis and dimensions........
Frame type: Steel
Rake (fork angle): 25.5°
Trail: 88 mm (3.5 inches)
Front tyre dimensions: 100/80-17 52H
Rear tyre dimensions: 120/80-17 61H
Front brakes: Double disc. 4-piston calipers
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disk
Rear brakes diameter: 210 mm (8.3 inches)
Exhaust system: 4 in to 1 with EXUP valve
.............Speed and acceleration..........
Top speed: 190.0 km/h -- (Red line 18.5k, maximum of 20k)
Power/weight ratio: 0.3191 HP/kg
