i have mehran 1994 model....m n mehran ka engine new banwaya hy....mje ap log ki suggestions chaiye Ac konsaaa lagwaon or kia changes krwani chaiyen.....
Mehran ma ac itna kamyab nhi ha phir b ager to aap lgwwna chahty hain then ajkal market main duet compressor milta ha to k used hota ha acha perfrom krta ha condenser multiflow lgwaeye ga evaporator b multiflow sae proper vacuum kerwa k Honeywell American gas charge kerwaeye it will cost u Around 20 to 25 max
koi hy karachi m apkaa jo ye sb kaam proper kr k de degaaa???
Sorry bhae have no idea about Karachi
No. It should cost around 12000 with the specs you've mentioned
Bhae jan market rate bohet high hain compressor condenser evaporator refrigerant yeah to hain main item baki pipes condenser fan evaporator box thermostat T (expension) valve yeah sb milla k ore labor aaram sy 20 cross ker jata ha ap ik rough estimate bna k btain kitna hona chaeye
Paayee jaan, I got the exactly same specs compete air conditioning unit for my car for 12000, including labour. And it's been a season, still the AC is super chill like a freezer
ni yaar...m n maalum kra hy....around 22 to 25 ka kharchaa aaa rhaa hy
Then they are overcharging you
karachi m koi jaaan pechaan ka hy tu plz refer krden
Nai bhai@qazisajid bro is quoting good rate... It's around 20-25
Duet compressor =7.5k with bracketBelt=0.4kPipes welding =0.4kCondenser multiflow=4.0kRefrigerant =2.5-3.0kDrier =0.7kInstallation =4k
Cheap work results in to big loss, try bringing quality in the work you get done, rather Saving 3-4k...
Also cooling coil which is if the same rate of condenser but well he can b disagree with me n u too
go to sabir north nazimabad ask for a fresh new installation. dont bargain. 03002152054
or for brand new OEM Denso equipment, go to thal engineering workshop behind tariq road. they supply the factory fitted ac for mehran.
Brand new system will not be a affordable deal original denso is not less than 15k i think he might have to spent 30+ for branded system well i have no idea about the prices of these days
i have checked with the different guys....sb kch na kch alag he btate hn...ek n mje kaha k bhai sanden ya denso ka rotary walaa ac ataaa hy wo lagwao wo lush chaltaaa hy pr new pr janaa no kabli....
Denso is best performance achi with less load rotary compressor ki Life kem but performance k liye acha ha
We've done a mehran euro with its own genuine system and got excellent results... It depends on the work quality and level of equipment and little things like drier bottle and charging refrigerant on weight method.
sabir is a trained expert and recommended by Xulfiqar bhai.
do exactly what he says and you will be satisfied.
new chinese compressor is for 13-15k. alone.
