Hassanbhai jo machine kay zariya ap ne bataya hai exhaust kay through, market ma kitne leta hai set krne kay leya ma soch ra hon wohi krwa lon ku kay mera se sahi nahi hona our kya method hota hai pichle bar compression test pe bhi chona lag gya tha
Bhai ye exhaust gas analyzer bhi kisi kisi k pass hi hotay hain.. Aur shayad ye bhi enercon walo k pass ho jahan se aap ko pehlay chuna laga tha..... Iss me aik sensor ko silencer ki tip pe lagatay hain aur carbon emissions check kartay hain aur phir mixture screw ko tweak kartay hain jahan carbon emission minimum ho jaien wahan set krr detay hain.
Chalo ma try krta hon enercon walo ko agr ise tra inho ne setting ki
Few days ago i saw my generator cover which is close to brake oil pipe was not connected to the generator so i used sareyay wale tarr tu bind it and in that moment i also tied the brake pipe and today it got leaked and then i welded it my mechanic said it will not get leak in 50 years i am worried aboutt it is it the proper way hassan bhai?
That metal brake line leaked OR it just blew away due to any rust?Proper method would be to get a new line. New line's are available in market.That welding method is just a jugaar it can fail anytime OR it can serve for a long time that's just a 50-50 situation.
Bhai mene us ko sareya ki tarr hoti hai na us se baandd deya tha vibration ki waja se us ma suii brabar kay 2 holes ho gya tha baki koi 1 percent bhi rust nhi the mechanic ne denter se pore golaye ma us jaga ko weld kiya hai and now he is guranting kay 50 saal ma bhi kahe nahi jata us ne system se air nikali the ab brakes zada strong ho gye hai our mere gare ma vibration the jo ap ko bataye the wo bhi almost na hone kay brabar hai sirf thore se steering main bss tension ye hai kahi leak na hoye wasa ye naya pipe kitna ka hota hai?
Bhai kuch kaha nahi ja sakta aisi situation k baray me. @Hassan1991 Bhai aap kya kehtay hain iss brake line k baray me? New available to hain lekin price ka mujhay nahi pta.
Metal brake lines?Local mil jati haien. Less then 50 per feet mil jati haien.
Local thek hota hain ya kabuli lon?brakes abhi bilkul fit chal re hain wasa brother!
Hassan bhai kuch dino pehla ham dost wasa he race laga re thay mazak mazak ma tu mene gare ko kafi bar floor kiya tha dot keh re thay kay gare brown black smoke de re the aj mene ghar a kr garam gare ko floor kiya 2_3 bar likin koi smoke nahi a re the silencer mera kafi ganda hai purane engine ku waja se ap ko tu pata hai swap krwaya hai engine mene is ki waja muxture setting hai ya silencer?Ye silver tip mene khud repaint ki the engine swap kay bad us ki condition ap kay samne hai
Cultus hai apki? Cultus ki kabli kahan milni haien. New sae haien mane sab new install ki hoe haien. Cultus ki apni new lines mil jaien gien.Gari carby hai na apki?
Carbureted car's me kabhi kabhi aisa ho jata ha. Jab aap ne zyada race di thi to gari uss time thandi thi kya?Aisay me abhi uss ka hot idle bypass kaam nahi krr raha hota aur mixture thora sa rich hota ha jab gari proper garam ho jati ha tbb hot idle bypass kaam karna shuru karta ha aur intake me direct air add karta ha mixture ko thora lean karnay k liye. Aur agar to aap gari ko zara khainch k chalatay hain to phir meray hisab se silencer ki condition bhi theek ha aisa hi sooty black sa hota ha. Agar aap moderately chalaien gy to silencer rusty brown color show karay ga agar Carburetor properly tuned ho aur ignition timing bhi factory setting pe ho..
Hassan bhai hann gare ko start kiya hua mera khayal se 5 min hua thay our it hardly reached the center point needle of temperature (thora sa nechay) phir use waja se ho ga yes you are rightwasa he tension par gye theyYar mechanic ne aj ku kaam kiya hai break ka our aik pipe change kiya us se mere vibration 90 percent reduce ho ge hai️
Abhi next kaam mene computerized tuning our timing ki setting krwao ga enercon se radiator cap change break line our choke ka...yar mene abu bakar ac wale bhai ko resister ka bataya us ko kuch nahi aye shaid ab ma khud he try krta hon pehla kahi se leta hon resister likin thermostat passenger seat kay nechay hai is ka kya kro?
G bhai carby hai ab kuch dino tk change krwa don ga ma...
Acha ma kal phir pics share krta hon phir ap guude krna sahi
Which engine you chosen for swap?Ither 3 hassan ho gya
Hassan bhai cultus ki apni engine ki assembly change ki hai yrAlhamdulilah going strong till now bss ajkal gear ki gonj ne tang kiya hua hai gear chnge krwa he dena cheya thaMa bhi yehi likhne wala tha kafi hassan a gya hain ider
Great.han gii
