No don’t do this as this will not fix your problem. Electrolyte specific gravity is adjusted once in start, to my understanding your batteries are brand new as you bought them in April. after this, you got to use de-ionized water for topping up, make sure, you buy a right bottle, not the one which faked to be de-ionzied.
Your issue is not batteries nor a bad cell or sulfuric acid content inside that cell. See, I can clearly see your issue after reading your older post. Your ups switches over to its slowest charging rate only at 27 volts, which is wrong. Ups will work, but batteries will never get a chance to charge its self fully and eventually will show a bad specific gravity.
Ups should switch over to its slowest charging rate only at 28 volts or least at 27.8 volts for rest of the charging till the set cut off voltage( if you have set it to 28.5 volts).
Once you have seen, that 28 Volts have been attained in good decent time, you should program such that its slows down the charging rate to its lowest value between 1-3 amperes till the cut off voltage which you have set it to 28.6 Volts. Then do not worry if ups keeps on charging the batteries till ever if voltage is between 28-28.6 Volts, because you know you are safe now and this little current is doing some good to your batteries like topping up the batteries with a right current which will repair any damages done to it in form of sulfate crystallization, bad C.G like which you are reporting right now and will increase the backup time and will truly charge the battery in a right way as needed.
