Homage starts charging the battery at fixed 10-12 amperes, AGS 132 has an amp-hr rating of 103 so already, and your system is operating at bottle neck settings or is out of specs by few amperes of charging. So it maybe combination of bad electrolyte and very fast charging rate. Verify the charging rate and make sure that least, it’s not set to 20amperes option.
Mostly I recommend 150-160 amp-hr rating of batteries along with imported ups, that’s why I wrote above that its important to read you’re your ups specification before selecting batteries for it as charging rate on these ups cannot be adjusted.
So likely reason: very fast charging and electrolyte quality.
if you have understood your mistake, I have a solution for you, which I will tell you later.
