M is not for mountain but it stands for Mud.Therefore M+S is Mud + Snow
Sent from my SM-N920C using Tapatalk
Thank you what tire pressure should i keep for smooth performance on bumpy roads?
Keeping in view of roads condition and heat of pakistan, I suggest 28psi maximum. More pressure will give you better mileage but bumpy ride. I personally tried 26 to 36 psi and found 28 best on desi roads of pakistan.
I knew it. It doesnt bumps on 26-28 easily. Any tip to make power steering to run more freely? What about steering fluid?
Mira has electronic steering. No fluid.Check steering rod
Sent from my H30-U10 using Tapatalk
Please suggest a good navigation unit with back view camera and a well reputed place to buy it from in Lahore. I would really appreciate if someone take some time out and respond to this. Thanks
Guys, from were can i find MIRA ES arm rest?
I bought dellson navi from hall road 2 days ago for my dayz which is my mira es replacment..
What is the procedure of cleaning throttle body and how long does it take?
How much it cost you. And how is result of videos ?
Go to some reputed service station, if you are from Karachi them bubbles car wash is the best place you could go for services like this with discounted price. Hardly takes about 30 mins, can be done by yourself but ill suggest you not to touch them yourself. One visit would solve your problem bro
Service station for throttle service?
Thank you.
Not the local pump ones. Reputed ones that are known for services like these, not every body can do this on JDM's
333 km done with 80 percent ac, short and long routes 28 pressure and many idle and traffic stops , ran my car by turning of the eco idle. 1 point is still remaining the tank hasnt started the reserve mark. What do you think about the avg?
Its good, keeping in view of karachi traffic and hot weather
Brother i need a help, since 10 days i have been noticing a weird smell coming from my car's bonnet that heating type of a smell, like burning type of smell, i drive for 2 3 mins then also i feel this smell. Where should i get my car checked?
@jexo, can u plz share what company/model# new plugs u used (in mira es) that made it smooth ?
I used denso's iridium, smooth as butter no jerkness, even a noobie like me can drive it with pleasure. And turn off the eco idle for reg braking
I was facing this problem from the very first day i bought my mira.. when i crossed 90 the smell came for.some time.. got it fixed from toyota.. some boot was opened due to which smell was coming in the cabin and later on the problem arose again but i ignored it.. nothinh to worry.
