Hi, Right now im using CD-70 and i travel approx 55-60 kms daily in Lahore. and It's super tiring on CD-70. My back hurts now because of that. So im looking for a good option for best comfort level. Im thinking to buy a YBR 125G 2019 or 2020 model as it comes in my range. Please suggest me some alternatives or kindly give genuine feedbacks on YBR. and i've heard that ybr gives 40-45km/l average. My main requirements for a bike is Comfort and fuel consumption.
You are right to mention that Ybr 125G gives 40-45 km/litre when driven at and under RPM 06. As far as comfort is concerned then is is quite comfortable as compared to its competitors. If your travel is on highways “only then” it is quite a good bike. Suspension is soft and is designed for highways where you will be using top gears (4-5). It drives smoothly on speeds upto 85-90 and get you to places quickly as compared to cd70 and other bikes. Reduced travelling time and a ride with less vibration reduces the stress on back.“Do not buy” it if your travel is within congested roads and traffic jams. You will regret as handling Ybr on slow speeds and low gears (1-2 ) is quite difficult due to its heavy weight.
My Major travel is on Canal road, Lahore Daily.
It all depends on the time of your travel. If you travel in times of extreme traffic then you are going to face troubles regarding handling of Ybr ( Ybr slow speed pe jhoolta hai left and right side pe ). But if your speed is going to be above 50 then there is no issue in its handling. Other than that the bike is all good and its maintenance from dealership is not even expensive.
How much does it cost for its maintenance ? and what about its parts?
Oil change costs around 1100 Pkr after 2000 km including small things like tightening chains and back brake etc. Air filter and spark plug costs around 600 each after every 12,000km. Other than that nothing else is required.
Perfect. So which model will you suggest to buy under 250k budget ?
I believe 2019-20 model should come. If I were you I would have preferred condition over model year.
buy a YBR bro.. best
YBZ DX is also a good optionFamily bike, same good suspension and comfort, good milage, no vibration.
Ybz or ybz dx.Buy anyone in very good condition.Parts are expensive as compared to CD 70.Almost double the price.But i am riding ybz for the past 5 yrs.No maintainace except oil,filter and Brake pads.After 5yrs now i need to get Chain sproket and both tyres changed.Chain Sproket 5000Rear tyre 4200Front tyre 3000Prices mentioned so that you can get idea of maintainance.
