@revengz..to be more precise it was G13BB..
The SOHC 16-valve G13BB has electronic MPFI Multi-point fuel injection, generating 56–59 kW (75–79 hp) at 6,000 rpm and 104–115 N·m (77–85 ft·lbf) at 4,500 rpm. The G13BB has 2 coil packs bolted directly to the valve cover, although early models still had the coil packs mounted to the left side of the head, traditionally where the distributor was located. This engine uses a MAP sensor to monitor manifold pressure, unlike the G16 series. This engine has a non-interference valvetrain design.
