Asslam-O-Alaikum
Car : Honda Civic 98
Engine : d15b 2 vtec (sealed never opened)
I'm facing few issues with my car and as per my mechanic my head gasket has been blown.
Oil was leaking from distributor side, so i installed the distributor inside seal and also changed the ring. so oil was stopped leaking from there i cleaned up the engine with petrol and washed the oily area. after driving 2-3 days there was no oil leaking and on 4th day i just take the car out from underground parking and when i checked the engine there was a very minor oil on engine so i drive the car to my mechanic which is hardly 2km and when i reached there huge amount of oil was leaked present on engine (area where engine code is written ).
so my mechanic was checking the distributor seal and he noticed that its not leaking from distributor it was leaking from head.. so he just opened the tapit cover and tighten the head blot. and again he cleaned the engine with petrol to check if it leak again. I drive the car whole day and there was no sign of leakage. Next day i checked the engine and there was no leakage so i just start the engine warmed it up and take it out from underground parking and when i checked again there was a very minor oil present on engine. so i took the car to mechanic and when i reached there oil was again leaking. he told me my gasket has blown and it causing oil leaking. So i drive the car around 2-3 hours and i showed it to another mechanic and the oil which was leaked gone and engine was dry. That mechanic told me it was old oil and its not from gasket. he checked the dipstick and there was no sign of water and oil mixing. so he advised me to wash the engine with petrol. I washed it my self after that i drive the car for another 2-3 hours but there was no sign of oil leaking.
1 more thing my car is making a little bit pressure in car radiator. like when i opned the radiator cap in hot car it throws a little amount water with pressure.
in last summer my radiator was weak and got some leaked so car was heat-up like 3-4 times. but when i installed the new radiator there was no heatup issue and pressure issue.
So which thing should i do now ? is it gasket or what ? i will today again check the car if it leak any oil again from that area.
Regards
