salam..all dear pws im facing RPM issue in my civic 05 model...CNG kit plus CNG cylnder complete serviced also throttle body..but still my car RPM 1500 onpetrol n 900 on CNG .... if mec changed settings on petrol 900 RPM then on CNGcar giving me 400 or 500 RMP without AC..on CNG wen i stopped car on any speed breaker or signal car goes switched off ... pls i need urgent help from all .. thanks
1 thing more agr RPM setting pertol pe 1500 adjuct keren then CNG pe 900 RPM hojata he n phir gari band nae hotejab break lagao ya gear change kero so pls muje advice keren...or mene throttle body 2 times serviced kerwake dekh li he but problem wese he hy
enercon g10or rehmans workshop chohar chawk peshawar road
Bro you need CNG settings, visit any nearby mechanic , who has experties in dealing with cars on CNG, discuss the problem with him. He will do the job for you. And don't pay him money untill you are satisfied.
I had the same problem in my 05 civic M/T like yours, finally had to change the throttle body sensor, after that it was all ok
there is a knob or a screw on cng kit which adjusts the idle rpm of cng ... have u tried setting it ... if throttle body had a problem you won't getting any auto choke plus you'll get other problems ... just get you cng set
@hasham30if this was the problem in ur car then u have wasted a lot of good bucks
mene kafi experts ko check kerwaya he sab setting ker dete hen per wo setting hot engine pe hoti hejab early morning car start kerte hen to dobara wohi problem hote he
kal mene aik CNG expert ko check kerwaya to usne throttle body ko khola n kaha ke throttle body pe koi paint ki line si hote he lite siwo kisi ne regmaar se saaf kerde he tab RPM masla ker rahahe kya ye baat sahi he?? kya muje b throttle body ko change kerna parega?
the paint mark is there on the throttle stop screw as it is not supposed to be adjusted. its factory set. but again it can be readjusted by calibrating the tps if the tps is not already disturbed. the tps should give 0.48 volts at closed state and at wot it should give 4.5 volts to the ecu. what the mechanic do is that they adjust the rpm on cng with that stop screw and disturbs the tps setting and you are looking for help here and there...
to muje ab guide keren ke ab muje kya kerna hoga plsss
or gaari lahore me he so agr koe acha sa mechanc he to lahore me muje uska bata den
Go to Magic Motors at Model town A block market. It is next to the gourmet Bakery.
yahan kisi ka nam wagera bata den jo expert ho
or pls muje guide be keren ke aik bar sirf settings kerwane ke bad dobara to nae hoga ye masla?
144 views n sirf 13 repliess
i am also facing the rpm issue in my civic 00 it is stuck on 1000rpm and sometime it goes up to 1500rpm what should i do???
Butterfly is getting stuck,get the throttle body cleaned.
Get the IAC Valve properly cleaned,it seems to me that throttle body has been badly messed up.
Can IAC Valve cleaned at home by any individual like my car is giving check light after some driving. What i should do ?
1500 on petrol? mine stays at 800..
