Like the title says, up for sale are 3-way custom components comprising of Hertz tweets and midranges and midbass drivers.
Have Nakamichi Made in Japan 3 Way audiophile grade crossovers to pair with these. Check pics below:
Specs:
Hertz HT 25 Tweeters:
Size mm (in.) 25 (1”)
Power Handling - Peak W 120
Power Handling - Continuous W 40
Impedance Ω 4
Frequency response Hz 1.6k ÷ 22k
Sensitivity dB SPL 92
Voice coil Ø mm (in.) 25
Magnet Neodymium
Cone/Dome Tetolon
Hertz HL 70 3 inch Midrange:
Size mm (in.) 70 (3”)
Power Handling - Peak W 100
Power Handling - Continuous W 50
Impedance Ω 4
Frequency response Hz 200 ÷ 14k
Voice coil Ø mm (in.) 20
Magnet REN® Neodymium
DV 165.3 Midbass
1. Large motor assembly for mobile voice coil control.
2. Pure copper voice coil, wound on conex former, for maximum lightness.
3. V-cone® for best off-axis response, clear mid-high frequency detail and
powerful bass.
4. TPU surround, for wide excursion and resonance damping.
5. DIN size basket protected by abrasion-proof dust paint.
6. Tin-plated, high current terminals.
7. Silver-plated lead wires for maximum reliability and conductivity.
8. Butyl rubber protective cover, against crashes and abrasions.
9. Epoxy glue for basket and motor system provides perfect coupling.
10. Low carbon content plates for maximum magnetic permeability and high
heat dissipation.
Technical Specifications:
Woofer size mm (in.) 165 (6.5)
Power handling W peak 160
W continuous 80
Impedance Ω 4
Frequency response Hz 50 ÷ 23k
Sensitivity dB SPL 93
Woofer Magnet size D·d·h mm (in.) 80 x 40 x 15 (3.1 x 1.6 x 0.6)
Woofer Voice coil Ø mm (in.) 25 (1.0)
Woofer magnet - High density flux ferrite
Woofer cone - Water-repellent pressed paper
Woofer weight kg (lb.) 0,74 (1.63)
Serious buyers can contact me on my contact number: 0344-4255560
Actual Pics:
