Every Item Is Brand New Except The Focal Solid 4 Amplifier
The Front Stage
2 way component Speakers System
Power Handling
CEA-2031 Power Rating: 110 Watts
Power Handling Capacity (RMS): 110 Watts
Power Handling Capacity (Peak): 330 Watts
Supported By Amplifier
The Focal FP 2.150 LE (Award Winning)
The very high power and the sound quality High dynamic capacity 1 x 400W rms available into 4 Ohms
[TABLE="class: cms_table_specs"]
<tbody>[TR="class: cms_table_even"]
[TD]Maximum cross section of loudspeaker cables
[/TD]
[TD]10mm[SUP]2[/SUP] - 7 AWG[/TD]
[TD="width: 5"][/TD]
[/TR]
[TR]
[TD="width: 50%"]Maximum cross section of power cables[/TD]
[TD]25mm[SUP]2[/SUP] - 3 AWG[/TD]
[/TR]
[TD="width: 50%"]Idle current[/TD]
[TD]0.8A[/TD]
[/TR]
[TR]
[TD="width: 50%"]Protections[/TD]
[TD]- Short-circuit - Continuous power - Thermal overload - Soft clipping - Over-voltage - Polarity reversal[/TD]
[/TR]
[TD="width: 50%"]Dimensions ( H x W x D)
[/TD]
[TD]50 x 350 x 280mm (2 x 13.75 x 11[/TD]
[/TR]
[TR]
[TD="width: 50%"]Weight[/TD]
[TD]4.8kg (10.58Ibs)[/TD]
[/TR]
[TD="width: 50%"]Product type[/TD]
[TD]Amplifier[/TD]
[/TR]
[TR]
[TD="width: 50%"]Nominal power measured at 13.8V continuously @ 4 Ohm[/TD]
[TD]2 x 150W RMS[/TD]
[/TR]
[TD="width: 50%"]Nominal power measured at 13.8V continuously @ 2 Ohm[/TD]
[TD]2 x 200W RMS[/TD]
[/TR]
[TR]
[TD="width: 50%"]Power in bridged mode measured at 13.8V continuously @ 4 Ohm[/TD]
[TD]1 x 400W RMS[/TD]
[/TR]
[TD="width: 50%"]Signal/noise ratio[/TD]
[TD]> 100dB (A)[/TD]
[/TR]
[TR]
[TD="width: 50%"]Damping factor at 4 Ohm[/TD]
[TD]> 500[/TD]
[/TR]
[TD="width: 50%"]Frequency response[/TD]
[TD]10Hz - 35kHz[/TD]
[/TR]
[TR]
[TD="width: 50%"]Input impedance[/TD]
[TD]13 kOhms[/TD]
[/TR]
[TD="width: 50%"]Input sensitivity[/TD]
[TD]0.2 - 5V[/TD]
[/TR]
[TR]
[TD="width: 50%"]High-pass filter[/TD]
[TD]50 - 150Hz (12dB/oct.)[/TD]
[/TR]
[TD="width: 50%"]Low-pass filter[/TD]
[/TR]
[TR]
[TD="width: 50%"]Finish[/TD]
[TD]Brushed anodized silver gun NEW FINISH[/TD]
[/TR]
</tbody>[/TABLE]
With Elite Focal RCA 3M Lead.
The Rear Stage
6-3/4" 2-way car speakers
<hgroup> </hgroup>
- 6-1/2" Access 1 Series 2-Way Car Speakers
- Power Handling:
- Peak: 240 watts per pair / 120 watts each
- RMS: 120 watts per pair / 60 watts each
- Butyl rubber surround
- Orientable, aluminum inverted dome tweeter
- 4 ohms impedance
- 25mm Voice coil
- 85mm magnet structure
The At The Back Rear ...
ALPINE SPR-69C
6x9" Coaxial 2-Way Speaker
System
100 Watts RMS
300 Watts Peak
Ultra Smooth 1" Silk Dome Tweeter
Swivel Tweeter
H.A.M.R. Surround (Patent Pending)
Multi-Layer Hybrid Fiber Cone
Large Square Wire Dual-Layer Voice Coil
High-performance Linear Drive Motor
FOCAL SOLID 4
(400w)4 channel amplifier, With a 4 x 75W RMS power into 4 Ohms and 4 x 100W RMS into 2 Ohms.
[TD]High-pass filter[/TD]
[TD]50 - 150Hz (12dB/oct)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Low-pass filter[/TD]
[TD][/TD]
[/TR]
[TD]Remote control[/TD]
[TD]yes[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Maximum cross section of speaker wires[/TD]
[TD]10mm2 7 AWG[/TD]
[TD][/TD]
[/TR]
[TD]Fuse(s)[/TD]
[TD]2 x 25A[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Nominal power measured at 14.4V continuously into 4 Ohms THD + N<=1%[/TD]
[TD]4 x 75W[/TD]
[TD][/TD]
[/TR]
[TD]Input impedance[/TD]
[TD]20 kOhms[/TD]
[/TR]
[TR]
[TD="width: 50%"]Damping factor @ 4 Ohms[/TD]
[TD]50 to 1kHz[/TD]
[/TR]
[TD="width: 50%"]Signal/Noise ratio (RMS)[/TD]
[TD]>100dB (A)[/TD]
[/TR]
[TR]
[TD]10Hz - 60kHz[/TD]
[/TR]
[TD]0.2 - 5V[/TD]
[/TR]
[TR]
[TD]35mm2 - 2 AWG[/TD]
[/TR]
[TD]- Short circuit - Thermal overload - Overvoltage - Polarity reversal[/TD]
[/TR]
[TR]
[TD="width: 50%"]Dimensions (HxWxD)[/TD]
[TD]1[SUP]3/4[/SUP] x 11[SUP]13/16[/SUP] x 7[SUP]7/8[/SUP]" (45x300x200 mm)[/TD]
[/TR]
[TD="width: 50%"]Signal/Noise ratio (1 Watt output)[/TD]
[TD]>80dB (A)[/TD]
[/TR]
[TR]
[TD="width: 50%"]Nominal power measured at 14.4V continuously into 2 Ohms THD + N <= 1%[/TD]
[TD]4 x 100W[/TD]
[/TR]
[TD="width: 50%"]THD + N @ 4Ohms[/TD]
[TD]0.02% @ 1kHz[/TD]
[/TR]
[TR]
[TD="width: 50%"]Power in bridged mode measured at 14.4V continuously into 4 Ohms THD + N<1%[/TD]
[TD]2 x 200W[/TD]
[/TR]
</tbody>[/TABLE]
With Elite Focal RCA 5M Lead.
Using Monster 4 gauge 1000w Kit (Monster 300 Series Kit)
Then a Woofer Pioneer TS-3002D4 (3500 Watt) With A Solid Audio AMP Mono. (4000 Watt).
& Other Goodies Also
