Hello, I'm letting go of my trust worthy SQ amplifier which I've had for a while but is in excellent nick. The amp is a powerhorse and has been regarded as one of the best sq amps around ( google it and you will know
I'm upgrading to something I've bought with me from Germany so this baby has to go. I was running a pair of JBL-GTO608c's and a JL Audio 12W3v2 in a sealed 1cu.ft with the amp. The amp was tuned for a SQ setup so the amp was never pushed hard to cause any harm. You are more than welcome to check the amp if you want
Specs:
Maximum power: 4 x 175 W
Rated power: 100 W x 4 (20 Hz to 20 kHz, 0.02%, 4 Ω4CH Simultaneous Output)
70 W x 2 + 260 W x 1 (3CH Mode)
200 W x 2 (2CH Mode)
Frequency response: 10 to 50,000 Hz
Harmonic distortion factor: 0.02% (20 Hz to 20 kHz, 100 W x 4 CH Simultaneous Output)
Signal to noise ratio: 118 dB
Compatible Speaker Impedance: 4 Ω (2 Ω to 8 Ω, Channel Mode: ST)
Input sensitivity: 200 mV ~ 5,000 mV
Low Pass Filter/High Pass Filter Cutoff Frequency: 50 Hz to 200 Hz (-12 dB/oct to -24 dB/oct)
Power supply voltage: 14.4 V
Grounding Method: (-) GROUND
Current Consumption: 56 A (100 W x 4 Rated Output) 1.8 A (Amplifier ON No Input)
External Dimensions: 367 (W) x 70 (H) x 350 (D) mm
Mass: 7 kg
Demand: 18k
