So all the CG Owners out there, what would be a safe level of alteration to get more out of your bike, by safe i mean for instance change the tires and such???
Salam..
Buddy you can check the following threads.
https://www.pakwheels.com/forums/bikes-3-wheelers/166142-hid-cg-125-some-other-changes
https://www.pakwheels.com/forums/bikes-3-wheelers/173882-smoke-indicators-matte-black-cg125
https://www.pakwheels.com/forums/bikes-3-wheelers/172689-cg-125-modification
if u r after engine alteratons, then many ppl say just removing the second layer of foam increases pick,also many quot a silencer upgrade,
the only alterations that i want is in the brakes.I want my cg125's brake to be much much better. These drum brakes are pathetic and provide no sense of security over 60km/h. After that if you need to brake Allah hafiz !!!
bluehorn same is the case with gs 150
