I went for 10000 service of my VXL (asked to change gear oil) and dealership saved my 7200/- showing me this
AET-306 is MODEL for New Alto
Recommended Gear (transmission) oil is75W for AGS and first change at 60000KM75W90 for MT and first change at 10000KM
@hash737Please explain suzuki ki sae 90 wali karwai
Bro your car invoice month/year?
Received mine on November 11, 2019.
Sir i bought alto vxl ags 2020, but its ac stops working after speed of 80 and then it start working on 100 and doesnt work above? Is this an actual reason or my car has it?
Alto AGS has auto AC cutout function which generally activates when you floor the padle especially during overtake when you need max engine power to speed up so it cut the AC.So do one thing slowly increase the speed and observe if AC still trips or not, if it does on normal increase in speed then consult suzuki as there might be some issue with sensor. And if it doesnt then you are good
Heard the same from a friend who used alto
am using the same ato ags and yes the ac does trip when u floor the car and you can actually feel the sudden acceleration; during normal speed the ac does not trip... i have taken the car till 110 the ac didnt trip point to be noted is that i didnt floor the car to achieve the speed of 110 i just taken it gradually
I Bro, I went Khi to Lahore in dec winters4 persons, we hardly took break like after 3-4 hours, qke motorway is straight n smooth, no issue, if car is not overloaded with less AC burden
ok... thanks for the info...
It's the same with VXR as well. If you floor it, the ac trips.
Yaar the dealer almost begged me not the change the GEAR OIL of my VXL AGS Alto but considering number of threads and experts opinions I changed the gear OIL. Believe me the OIL which came out from the car vs the new oil which I poured has no identifiable difference. Theres not a 0.00000001% noticeable improvement in gear shift or performance. So changing gear oil of AGS is wastage of money. Please dont do that.
Your car invoice / delivery month?Secondly which gear oil did you pour again ?And from which dealership did you get 75w?
Since when is the gear oil replaced to 75W? Mines oct 19
From feb mid or feb end 20202019 and Jan 2020 cars have sae 90, 100% sureThose who have changed, reported massive difference
Will get it changed at 10k service probably.
Can you please share source of this information about incorrect gear oil poured by PS? As I received below response from customer care. If they really poured incorrect oil then replacement of oil should be free of cost.
Oct 2019 invoice. Done the change from Gujranwala dealership.They tried to convince me that original oil coming from factory is also the same 75w and 90sae are only rumors floating in the market still I didnt listened and changed the gear oil to 75w. Regreting the decision. But At least now I am sure that the dibbiya is running on correct gear oil.
Do you have remaining 0.8 litre?Secondly please share oil packing pic for other members
