can anyone tell me what is the function of this card button??
Sent from my SM-G530H using PW Forums mobile app
old model was 3 speed auto Hx24 new alto is 4 speed auto or cvt ....
use zic ATF 3 or if you can buy liqy molly ..best for it ...
yes 2007 model G2 in goo condition can be bought in your price range
oh thats great ....4 speed is from mazda carol and nissan ...my car is still running on 3 auto ....its been doing good for last 60k .....
will see when it needs replacement ..i will go for 5 speed manual or 4 speed auto
with ecu ? u mean CVT gear ...normal 4 speed does not need an control module
It's actually not a button but a card holder. For example holding a toll tax card given at Motorway.
Sent from my SM-N920C using Tapatalk
what is this electronic choke, could u show it in picture. it will of great help to me
What is this PHONE button on top right corner
Plz let me know how it works
bro how did u open clean nd reinstall the throttle body ??
Dear i have japanese alto 2014 model .driven 30000 km. When i turned on the switch i heared the low beep sound. When i went out and searched nearby battery and engine..beep sound was little more. It is the same sound when headlight is turned left on and you remove the keys from the switch. But magnitude of this constant beep is very low. Difficult to hear inside if doors are closed.
To check it physically, get on the ground, see under the car, if a shaft connects engine with the back wheels, then its four wheel drive if not then two wheels.
Can somebody help me with Engine oil capacity for Alto eco s model? Mine got filled with 2.7L with oil filter. I heard its 3L though
Sent from my SM-N910G using Tapatalk
If you change oil filter than 2.8 otherwise 2.7L
Oh i see, why does everybody quote 3L then?
They are wrong. 3L goes way higher than upper mark of dip stick. 2.8 L perfectly match that mark
Where to find the Engine number on Alto 2013? Documents only mention Chassis number, can't find the engine number.
You have to look on the Engine Block. The flashlight will help you in locating it.You will find it below the airfilter position printed on the Engine bloc
Salaam's guys.
I'm looking for Suzuki Spacia 2013 user manual in English.
Any help would be much appreciated.
Thanks in advance.
your car is 4 forward gear... no need to change transmission...
Plus you cannot get its bodykit, not available atm...
