oh yes, after reading over the swift service manual i downloaded
1257 pages of hell- no kidding
it says engine coolant needs to be replaced, ill be doing that
engine oil...will do that
spark plugs. it says to replace every 15k km if car is without h2os and using nickel plugs, every 60k if without h2os and using iridium;
otherwise (with h2os) every 45k for nickel and 105k for iridium.
How do i know if my car has one ( as i said i bought it from the dealership ) and which plugs are preferred at which timing interval ( the thing you set on the plugs before you plug em in)
air cleaner filter is also to be replaced, where on earth to get one, what is cost...
and the manual transaxle fluid is due to be changed. which one and how much?
same with the brake pads-are to be inspected and changed if needed ( which is available cheaply?)
lastly the air conditioning filter is to be changed ( i drive i dusty areas a LOT so this seems to be important;especially during the summer)
and sorry to be pushy but you dident reply about teh window washer issue.
TY in advance
