complete 4Liters goes in. 3.5L is for Cultus/baleno
No bro this is one thing i have always used Suzuki genuine in my swift and there is alot of differenceAnd i dont know in ur city but one available at carachi motors in Karachi is not the guard one
A.O.A guys.I've 3 questions so please kindly give some expert advice. My swift 2013 with 20k on odo
Ok.. all points noted.Will go to suzuki dealership for complete checkup..Thank you.
20k wow i was thinking its only me who has the lowest mileageMine is also 2013 model but 40.5k driven
Its 19.6k to be very exact.Which engine oil do u use
Its 19.6k to be exact.Which engine oil do u use.
I always used zic x9 5w40 but since its too much expensive nowJust a week back i have bought both Shell Ultra 5w40 and Caltex ProDs 5w40 but uet not used any of them
I'm using Caltex Havoline 5w-40 Gold Pack in my Swift.It run smooth and change interval 5,000km.
Aoa. I recently bought a swift 2011 with 75,000 km on the odometer. The carās drive and performance is perfect except that I get an annoying whining noise in the first gear. It increases as the rpm goes up. Once I change to 2nd gear it is reduced to minimum and after that thereās no noise. I showed it to the mechanic and also gave him a test drive. He said thereās no issue in this noise itās completely normal. But itās so annoying, does anyone has the same problem?The gear oil got changed at 75k
Gear oil was supposed to be changed at 10,000 KMS first..Then after each 40,000 KMS.
Ask from previous owner whether he changed gear oil at 10k and 40k odo or not ?
Btw that sound is normal in swift.
Oh thank you. Yes previous oil changes were made on time but i changed all the fluids after buying just to be sure. Well then turns out this noise is an annoying gift from pak suzuki
So which gear oil you are gonna go for.??
He has already changed
Ok rephrasing my question.
Which gear oil you used ?
I used Kixx GL4 i guess 5w45 if Iām not forgetting
That's wrong lol.You must've used either 75W-90 or 90W-140
I actually donāt remember the figures after GL 4. I just checked kixx gl 4 doesnāt even have 5w-45 i think it was 75w-85 i just checked the bottle on their website
5W-45 is actually very thin to be used as gear oil. It's only good to be used as an engine oil.
