dear frnds,tell me the time/milage to change my honda city vario 2008 gear oil.and recomend me oil also.thanks
for gear oil check ur owner manual as oil is concerened use caltex havoline or castrol gtx
I think 40K is the limit
50k max
i think you're referring to transmission fluid?well it shud be changed at 40k
honda guys recommend it to be changed at 40,000kms but many people started feeling jerks frm tranny after 30k kms, so its better that u change it on 30k kms, but do not exceed 40k kms ....!!!
@xxxUsually on every 40k you should change it and check for changing it from Honda.
50000 kms
City Vario's gear oil, you should change it a lot earlier than the 30 - 40k mark if you love your car i ll suggest every 15 - 20k kms.A thousand rupee every 20 thousand kms in not a big deal if your transmission stays healthy.
what abt normal auto transmission when should we change the oil
Honda Vario has a CVT (constant veriable transmission) automatice transmission and only use Honda or Toyota CVT fluid and dont change it till 80,000 km as mentioned in Honda Manual
guys can any body help me regarding the ATF Oil Change in 2000 VTiaccording to the user manual
thnx
It is 40K or three years which ever is earlier and please use Honda's Auto Transmission Fluid.
@shirazkhanChange ATF after every 40k from any TOYOTA AUTHORISED DEALER.and use Zic Fully synthetic DEXRON III.
at any toyota dealer ???
what do you mean , i m taking about honda civic 2000
yes you are right Honda civic to Honda dealers.
Vario me toyota CVTF oil dalne se koi issue to nh ata? I've 2005 honda city vario
No bro. Use genuine honda CVT oil.
