1. Dealer-Programming additional Sentry Keys (requires ONE original key) In situations where only one key is available, keys must be programmed by the dealer via the Secured Access Method. The Secured Access method applies to all vehicles. This method requires the use of a DRBIIIt scan tool and will also require that you have access to the unique four-digit PIN code that was assigned to the original SKIM. The PIN code must be used to enter the Secured Access Mode in the SKIM. This PIN number may be obtained from the vehicle owner, from the original vehicle invoice, or from the DaimlerChrysler Customer Center. Refer to the appropriate diagnostic information for the proper Secured Access method programming procedures.
2. Self-Programming additional Sentry Keys (requires TWO original keys)
"A" through "G" below is a quick summary of the steps that are required for programming. Following this list, "1" through "6" takes you through the same process in greater detail.
Quick Steps: A. Purchase a blank key and have it cut
B. Insert original key #1 into ignition and turn to On
C. Wait 5 seconds and turn key to off
D. Immediately insert original key # 2 into ignition and turn to on
E. Wait 10 seconds for SKIS indicator in dash starts to flash
F. Turn ignition off, insert new blank key and turn ignition back on
G. Once SKIS light stops flashing and turns off, your new key is programmed
Detailed steps:
(1) The first step of course is to acquire a blank transponder key. These can be purchased from your Jeep dealer or bought online. Online prices are usually around $20.00. You can then take the blank key along with one of your original keys to any key maker or locksmith and have it cut to match, just like with any other key.
(2) Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the On position.
(3) After the ignition switch has been in the On position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the Off position. Replace the first valid Sentry Key in the ignition switch lock cylinder with the second valid Sentry Key and turn the ignition switch back to the On position. The second valid Sentry Key must be inserted in the lock cylinder within fifteen seconds of removing the first valid key.
(4) About ten seconds after the completion of Step 3, the SKIS indicator in the instrument cluster will start to flash and a single audible chime tone will sound to indicate that the system has entered the Customer Learn programming mode.
(5) Within sixty seconds of entering the Customer Learn programming mode, turn the ignition switch to the Off position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the On position.
(6) About ten seconds after the completion of Step 5, a single audible chime tone will sound and the SKIS indicator will stop flashing, stay on solid for three seconds, then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the Customer Learn programming mode and the vehicle may now be started using the newly programmed valid Sentry Key.
Each of these steps must be repeated and completed in their entirety for each additional Sentry Key that is to be programmed. If the above steps are not completed in the given sequence, or within the allotted time, the SKIS will exit the Customer Learn programming mode and the programming will be unsuccessful. The SKIS will also automatically exit the Customer Learn programming mode if it sees a non-blank Sentry Key transponder when it should see a blank, if it has already programmed eight (8) valid Sentry Keys, or if the ignition switch is turned to the Off position for more than about fifty seconds.
NOTE: If an attempt is made to start the vehicle while in the Customer Learn mode (SKIS indicator flashing), the SKIS will respond as though the vehicle were being started with an invalid key. In other words, the engine will stall after about two seconds of operation. NOTE: Once a Sentry Key has been programmed as a valid key to a vehicle, it cannot be programmed as a valid key for use on any other vehicle.
