Nope. Altis 1.6 requires 4.2 ltrs if oil filter is changed. And its better to change oil filter every 5000kms with the oil.
Try creating a folder and do not put the songs in the root folder of the USB.
I had the same problem and i fixed by creating folders and not copying songs in the root USB folder directly.
Is there any precautions to drive new car for some kilometres? Any tips or advise are highly appreciated.
Consult owner manual and see engine breaking
No overspeedingDon't drive on one gear for longer stretchesNo hard brakingDon't idle for long etc
Just do not push it hard for initial 1,000 kms. No sudden acceleration, no hard braking. Do not drive it on constant speeds.
My father's Altis 1.6 is booked and will be delivered in April.He is much concerned about the security of car. So, how much the immobilizer is effective? Any other security measure can we take, pls guide.
Get it insured...immobilizer is good but again the amount involved needs insurance...simple
Installed auto dimming rear view mirror.
Auto dimming off
Auto dimming on
Bought from Aliexpress. No customs levied.
PKR 6,955 6%OFF | GreenYi Car Electronic Anti Glare Auto Dimming Rearview Mirror, Special Bracket Replace Original Interior Mirror. https://s.click.aliexpress.com/e/1QEtV5P
Please share wire xover picture and also wiring in the oillar
Dear Friends,
Below is the link of Survey related to the Final Project of my MBA. Please spare 10-15 minutes to submit your opinion. Also help me in gathering maximum responses by sharing the link on Facebook and Whatsapp Groups.
https://goo.gl/forms/s4rgaNf2G8azKjBa2
Thanks
Wire was hooked to an accessory cable behind glove box.
sir aliexpress ? and any wire tempering during installations ?
majority of the modern engines have their pre-running done prior to fitting into cars nowadays. however; you should be a little easy and drive gently in the early days. 1000 Kms takk halka haath. See the manual if there is anything u can find please share. Btw, congratulations for getting a new car ! good luck
dua !
Thats correct. Pre running is done by the companies. no need to do hath halka.
