I'm looking for some good quality fog lamp led's. Can anyone recommend any? Preferably delivery from Pakistan as aliexpress takes too much time for delivery and mine are fused. Don't trust shops for things i know nothing about
Pakistan mein apka koi khaas brand ki LED nai milni cheapest of the cheapest LED hi milni hai.
Dealership will.put the oil they have in stock..no.matter hoe crap it is..they least bother about customer loss. Toyota engines are robust enough to handle these abuses long enough to get the warranty expired
I am using Phillips Ultinon essential 16W LEDs in my Grandes stock foglamps... They are extremely bright and have heat sinks instead of fan.. I ordered from Ali express and cost me around 7K but they are also available on daraz for 11K
Here is how it looks like
Thank you. I think i will order these as well. Just to be sure, it's H11 for grande, right?
Yes Grande foglight compatible
Sorry to ask so many questions. Did you get the H11 head lamp or H11 fog lamp? Will there be any difference between them?
Ali Express link please
https://www.aliexpress.com/item/33051389271.html?spm=a2g0o.cart.0.0.58db3c00aXVHXt&mp=1
No problem you can ask as much as you can... So H11 foglamp one... Not sure if there will be any difference but i bought the H11 foglamps
Thank you. Just ordered. Lets see when they arrive.
Only difference is wattage. Fog lamps are low wattage.
Yes you are right.. Foglamps are 16W and headlights are 55W..
Hi guys hope you all good .just a quick question. CAN WE INSTALL GRANDE 2020 LED HEADLIGHTS ON ALTIS 1.6 2020 . AND IF ANY BROTHER HAS INSTALLED PLEASE SHARE ?
I just checked again. They are both 16W.
Bi-LED headlights aren't 55W. They're less than 30W
Can we get amber color LEDs for fog lights?
I doubt itBecause Grande headlight has some kind of special technology which adjust level something I am not sure but I doubt it I just saw SAAAAAD from sehgal motors install Grande FL headlights in Pre FL so it should be possible but that special feature wonât work
That special feature is a sensor fixed in rear suspension beam which auto adjust the height of the low beam depending on the weight you are carrying... and yes when you install the light on 1.6 altis then this feature wont work
Can anyone share the front cam view of the grande. My camera is not working since I bought the car and the replacement Chinese I got has a view which doesnât seem to help much with parking. Does the default camera help? Just want to see the view and compare.
