@all
Can somebody post the picture of "O/D" button. I would really thankful to him.
i have changed oil filter (toyota) and engine oil (shell) the problem is still there ... hmmmm i will be going to get the sensors checked and see if carbon is the problem
@baqaiI would appreciate if you would share after getting rid of this problem.
Can somebody please post the picture of "O/D" button near the gear lever. I tried hard but unable to find it out. Please post the picture.
@baqai
Did you remove ur catalytic converter?
Where else can one do an OBD on their Vitz cars besides going to Toyota which I think will be quite expensive???
@tyrone_40
How much OBD costs?
@tyrone,
he still has it installed. I have recommended that he get it checked out to see if thats the trouble maker.
@smartkhan
I have no idea thats why I asked if there are any other places where u can conduct an OBD on your vitz in Karachi.
NO idea how much it costs. Maybe someone on the forum who has done it will be able to tell.
@ SmartKhan
Abt the Check Engine Light, its either the Sensors or most probably your Catalytic Converter is blocked ! Get your CAT removed as it must be blocked as these cars were meant to run on UNLEADED FUEL but here in Pakistan, we have LEADED Fuel so the lead compounds block off the CAT hindering Exhaust flow !
How much Catalytic Converter does cost?
You dont need a NEW CAT ! You have to remove it ! Even if you buy it (its expensive), you'll have to replace it after a short time (maybe 3000kms).
So best is to just Remove it and put a straigh de-cat type pipe over there !
@kiani1
Thanx...
But help me regarding "O/D OFF" light which appears on my digital meter. How can I fix this problem. I am unable to find a button near gear lever. Can somebody post the picture of that button.
The most important thing for you to do first is to get the "check engine" problem fixed.
if the o/d light isnt comin off even afterthis button then there must besomethin wrong ie it can b simple electrical fault. also the check light thing its best to check the sensors if u hav cng in the car check the o2 sensor. also use quality oil n filter it makes ahuge difference in the vitz
No Problem ! Abt the OD Button, I cant help you cuz I dont have Vitz !
@aabirgti
Thanx for helping. Which model do you have ?
i hav a 99 vitz 2 door wit custom bodykit and adjustable suspension i only had it a month.
I am in office now. It means my car ( model 2000 ) will also have this button. I'll go home and see.
my friend has 2001 and it has this button.urs should have it too
cool, if u hav any probs or jus wanna discuss stuff abt vitz jus contact me
Ofcourse I'll contact you if i'll have any problem with my Vitz.Do you know how much OBD costs?
