Dear All,
Asalam o Aleykum, I have already read the topic Two Cars with the Same Registration Number but have another related question:
is it possible specifically in PUNJAB to have two vehicles registered in same year with same number plates but with following scenario.
if yes then how to search & verify both on Punjab Excise Website ?
Thank you,
Regards,
Muhammad Asad
Yes it is possible entre the numbers on website and see you self
17 and 17a is the difference
@qwertypoiu: Thnx for reply, but it shows only 1 result.
I just wanterd to make sure that the onther number with A (ex. LEH-17**A**-3971) is genuine or pirated.
Yes it is possible. Suppose the city of registration is Lahore, the Series will start from LE-17-xxxx, then LEA-17-xxxx and so on, if the series ends within the current year, the next series to start will be LE-17A-xxxx, then LEA-17A-xxxx and so on.
Thank you Zia Bhai for guidelines.
A means Again
No it doesn't mean that. Its just a series if somehow that series also ends in that year, next series will be LE-17B-xxxx, LEA-17B-xxxx and so on
Never seen B series..if you saw plz share the image
B series has not been introduced yet, I am just telling you if in any case A series also ends, next series will be B, C, D and so on. A does not stand for again.
