This morning i thought about making a duplicate key for vitz 2007 model as i only got one key with it which has remote door lock function.
After making a new key from the chabi wala, i told him that this car might have immobilizer so it may not work in the ignition, but doors were opening fine, he said no it will and he inserted the key in the ignition system which didn't work, after this i inserted my original keys and it also didn't work, i was not even able to turn the keys.
At this time i thought that may be something terrible has happened and even original key may not work now, but after around 10 minutes when i inserted the original key again it was accepted by ignition system and it easily turned around and the car was started as well.
So i wanted to know if this thing is usual with immobilizer system or its something unique in vitz that if you insert wrong keys it locks the ignition area for all keys for around 10 minutes and then automatically release it?
Also any place where a new key can be made for cheap with ignition system compatibility.
Thanks!
