everything you want to know about the 1970 KE20
Technical specifications of 1970 Toyota Corolla 1200 This record added before December 1995.
Last modified 2006-06-29.
Carfolio.com ID 53900
bodywork
Type 4/5S SAL
Designer
Number of doors
dimensions & weight
Wheelbase 2335 mm 91.9 in
Track front 1255 mm 49.4 in
rear 1245 mm 49 in
Length 3945 mm 155.3 in
Width 1505 mm 59.3 in
Height 1375 mm 54.1 in
Length:wheelbase ratio 1.69
Ground clearance
Kerb weight 770 kg 1698 lb
Weight distribution
(Front) 54.50 %
Fuel capacity
Go to more manufacturers or other Toyota models
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code
Manufacturer Toyota
Type S-4
OHV
8 valves total
2 valves per cylinder
Main bearings
Construction
Bore × stroke 75.00mm × 66.00mm
2.95 in × 2.6 in
Bore/Stroke ratio 1.14
Displacement 1166 cc
(71.154 cu in)
Unitary capacity 291.5 cc/cylinder
Compression ratio 9.00:1
Fuel system 1 Ai carb
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter N
Max. output
(DIN) 68.9 PS (68.0 bhp) (50.7 kW)
@6000 rpm
Max. torque
(DIN) 88.0 Nm (65 lbft) (9 kgm)
@3800 rpm
Maximum rpm
Coolant Water
Specific output 58.3 bhp/litre
0.96 bhp/cu in
Specific torque 75.47 Nm/litre
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h
0-100mph -1.00s
80-120km/h
(50-70mph)
in top
0-Quarter-mile 18.50s
0-Kilometre
Top speed 147 km/h (91 mph)
Fuel Consumption
CO2 Emissions
Power-to-weight 88.31 bhp/ton
