Shift lock is a shifter lever lock. Shift lock prevents Shift lever from being moved from Park unless brake pedal isdepressed. In case of a malfunction, shift lever can be released by depressing shift lock override button, located near shift lever
MISTER SHIFT LOCK IS USED FOR CHANGING GEARS WITHOUT STARTING YOUR CAR.U JUST NEED TO INSERT THE KEY LIKE IN CIVIC AND IN JAPANIES CAR U CAN PRESS THE BUTTON AND CHANGE THE GEAR WITHOUT STARTING THE CAR.
