I have bought a Honda City Steermatic 2006 model. It's a 151k driven car with engine changed after 150k due to blown head gasket. Following is the list of stuff I have done so far...
Changed AC compressor. Got it charged with American gas.
Changed CVT fluid, e gone oil, filters, rear leathers,
All original Honda fluids
Catalytic converter along with O2 sensor.
Changed plugs.
Fuel avg remained at 8km peer litre.
Got it scanned from iqbal electrician multiple times near chauburji Lahore. No error codes and same results.
Got it scanned from an electrician and same results.
Got throttle body serviced .IACVvalve cleaned
Same result.
Got throttle body changed. Same result.
Got tappets adjusted. Same result.
Gotta radiator cleaned.
Got coils checked two times.
Got vaccum leakage checked. It's fine.
Pick is fine, rpm is almost stable at 600. With ac at 800.
3 mechanics and two top electricians with scanners have given it a clean chit.
Now I feel like car is running in open loop. Exhaust pipe sounds heavy. Like engine is running under heavy load. Pick is fine with and without AC. Car does not have any other issue. Engine, gear, mechanical , electrical seem fine .
Now I am very disturbed as it's causing dent on my pocket. I am here to seek help of senior pakwheelers on the issue.
Can't tolerate it like this.
