Aoa,
I got the following stuff for a project but didn't end up using them. All the parts are in the same condition as when I got them. Need to clear up space so these need to go out as soon as possible.
All of the parts are being sold AS-IS.
Contact: 0300-8504180 or 03314441181
Serious buyers only.
ECU boxes:
There are scuff marks but no cracks what-so-ever on both. All mounting points are intact and not broken off. Both have the internal connector holders.
One has a rubber seal attached to it (to prevent water coming in from the wiring harness)
One has the top cover and cooling pipe attached.
Price:
Rs.2000 (Reduced) for the one without cover and cooling pipe.
Rs.3500 (Reduced) for the complete one.
Relay box No.2:
It has scuff marks, other than that the condition is good. All mounting points are intact and there are no cracks in the shell. All of the relay and fuse holders are good.
Price: Rs.1800 (Reduced)
Shift Lever:
It is in a mint condition. The shift lock control ECU and locking solenoid work perfectly, Movement is smooth and unobstructed. There are no cracks in the body and all mounting positions are intact.
Knob is worn out but that can be replaced with any other screw-on knob.
Price: Rs. 4700 (Reduced)
Inner Dashboard Wiring Harness
Complete uncut wiring harness from one side to the other of the interior. Has all of the connectors and junction boxes. Majority of it is in the factory sleeve. All three junction boxes are in mint condition and work perfectly. There is no damage to the internal circuitry, Also includes both side harnesses that go to the back of the car but both sides are cut midway.
One mounting point of the passenger side junction box is broken.
Price: Rs.14,000 (AS-IS) (Reduced)
