Results 1 to 8 of 8
Thread: D-S transmission in vitz 2007
    amadeus's Avatar
    Aug 2005
    37
    139
    Default D-S transmission in vitz 2007
    Hello,
    What is the D-S transmission in vitz 2007, when you shift the gear right it goes it "S" and on shifting it to left it goes to "D", i normally drive on "D" but not sure whats the purpose of "S"?
    amadeus's Avatar
    Aug 2005
    37
    139
    so ....no one knows about it?
    so may people have new vitz!
    BMW7Series's Avatar
    Feb 2006
    22
    8,951
    i think it is triptronic
    Maa Da Laddlaa Vigar Gaya.... Chevy Aveo Ly K Nikal Gaya.
    Spano's Avatar
    Dec 2006
    34
    6,891
    20
    321 Post(s)
    2 Thread(s)
    its used for engine braking, like we use low gears for braking in our manual cars.
    Over driving is not possible in this S mode.
    D-S transmission in vitz 2007 -952677
    Ehtesham Bokhari
    https://www.facebook.com/sebokhari
    amadeus's Avatar
    Aug 2005
    37
    139
    what you mean by over drive, for example if i switch to "S" then gear ratios will be long?
    and with "D" it will be normal drive?
    Naweed's Avatar
    Jul 2008
    50
    3,469
    12
    122 Post(s)
    3 Thread(s)
    Patience my dear, patience
    D is for drive with max gears available I think Vitz 07 is 4 forward and S (can be named slow) drives the car in 3 forward, then there is B (it should be named braking/brakes) and gives you 2 forward. Don't drive for too long on S and B the gear box heats up and may cause permanent damage (read manual or download from net)
    "You have not lived today until you have done something for someone who can never repay you."
    amadeus's Avatar
    Aug 2005
    37
    139
    in manual which you have posted earlier, the transmission diagram, doesn't correspond to the gears that i have in my new 07'vitz
    This one has only 3 gears and "d and s are side by side"
    Spano's Avatar
    Dec 2006
    34
    6,891
    20
    321 Post(s)
    2 Thread(s)
    its the same like yours .... 3=S and second difference is that its for left hand drive thats why 3 becomes outwards side.
    functionality is the same.
    Ehtesham Bokhari
