Results 1 to 6 of 6
Thread: vitz 2007 key and immobilizer system
    amadeus's Avatar
    Aug 2005
    37
    139
    Default vitz 2007 key and immobilizer system
    This morning i thought about making a duplicate key for vitz 2007 model as i only got one key with it which has remote door lock function.
    After making a new key from the chabi wala, i told him that this car might have immobilizer so it may not work in the ignition, but doors were opening fine, he said no it will and he inserted the key in the ignition system which didn't work, after this i inserted my original keys and it also didn't work, i was not even able to turn the keys.
    At this time i thought that may be something terrible has happened and even original key may not work now, but after around 10 minutes when i inserted the original key again it was accepted by ignition system and it easily turned around and the car was started as well.
    So i wanted to know if this thing is usual with immobilizer system or its something unique in vitz that if you insert wrong keys it locks the ignition area for all keys for around 10 minutes and then automatically release it?
    Also any place where a new key can be made for cheap with ignition system compatibility.
    Thanks!
    Newbie Follow
    dohc_waseem's Avatar
    May 2009
    34
    ya its a important question, let experts to come.
    Rawfay's Avatar
    Sep 2007
    26
    1,034
    thts wht immobilizer does. I've experienced this in our camry 02 in saudia.
    1. Live and LET Live !
    rohaansaeed's Avatar
    Aug 2006
    23
    3,703
    47 Post(s)
    2 Thread(s)
    totally normal
    City SX8 - Civic ES - Accord SiR CF4 F20B
    Build Threads http://ow.ly/cZpvx and http://ow.ly/cZpDb
    killervtec's Avatar
    Jun 2008
    34
    3,666
    57 Post(s)
    kia chez???
    amadeus's Avatar
    Aug 2005
    37
    139
    i thought it cuts fuel and EFI system circuit when immobilizer is activated, but keys will turn normally, because thats what happens in liana
