Results 1 to 10 of 10
Thread: help neded ragarding vitz 2000
    thesialkotian's Avatar
    May 2008
    Sialkot
    32
    72
    Default help neded ragarding vitz 2000
    A.o.A
    i struck a problem in my vitz 2000 dat it is creating a problem in petrol while it is working on cng quite gud but on petrol it is missing and also making strange sounds in the cylincer on petrol.i go to a mechanic and of the view of him there is prob in its fuel pump,but after changing the pump the prob is still remain so now kindly suggest me a better suggestion.
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    Throttle body service
    Suggestions required
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    yeah, TB service and also check your coil packs, and see if you're missing spark in one of them?
    https://www.facebook.com/OsamaAbbasPhotography
    ahmedshaikhani's Avatar
    Feb 2009
    26
    1,120
    2 Thread(s)
    Don't get your car throttle body opened because it gives engine light. Get it your car checked at Khan Motors at Phase II on computer he will tell you. But Khan motors charges are high.
    4G13 SOHC Turbocharged. 4G93T Mivec Turbo with GT30R, Emanage Ultimate 1.5Bar, 353Whp. 1JZ-GTE, Single Turbo, 4G63T 6th Gen FWD. Team DEKA.
    anilnaqvi's Avatar
    Mar 2008
    4,113
    thesialkotian
    throttle body need service but get it service by sum professional like toyota 3s
    ahmedshaikhani
    seems sum unprofessional mechanic service urs and messed up with sensors anyhow its normal to service tb but b careful always serviced it by sum professional else chk engine light comes for sure
    Ford Mustang 1974 Restored,Toyota Celica ST 1974 Restored,& Celica ST 1973 Restored
    Nov 2008
    35
    10,044
    10 Post(s)
    ^^^offcourse it gives check lite but after installing it back, check lite goes off as well
    Feb 2009
    26
    1,120
    2 Thread(s)
    To service Vitz throtle body, its the different way because it has many sensors. Its procedure its different from other cars ask any professional mechanic, and engine light doesn't goes so easily if sensors are messed up.
    anilnaqvi's Avatar
    Mar 2008
    4,113
    panicslayer
    bhai jaan read my post carefully
    May 2008
    Sialkot
    32
    72
    thnx a lot guys
    Feb 2009
    26
    1,120
    2 Thread(s)
    Your welcome and do let us know the result..!!
