Results 1 to 7 of 7
Thread: VITZ ABS and tyre pressure
    123khanashar's Avatar
    Jan 2009
    44
    57
    Default VITZ ABS and tyre pressure
    Guys,
    Yesterday I use my car after approx 1 month , while driving I noticed some sort of vibration and
    noise under my brake pedal or near brake pedal at engine side. (which I didn't take it serious)
    Anyway the next is that I stop at market and park my car. When I comeback ans starts car, I noticed that the ABS light is not shown is meter( it was shown ON before while I crank my car and OFF after few sec) Anyways I try twice but all time same .
    next morning I noticed that tyres have some low pressure. When I went to trye shop , I surprised that my front wheels have 15 PSI and rear wheels approx 10PSI.
    Now the question is that does this tyre pressure effets ABS or tyre pressure have nothing todo
    with ABS system or its light.
    Thanks and Regards
    Ashar
    Moved to CNG/Mechanical/Technical/Performance - MOD
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    it just glows on ignition and off when the engine is turned on no need to worry
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    If the car will lose the will definately work
    Jan 2009
    44
    57
    @asad1 ,
    ok but my car ABS is does not glow , before or after start.
    thanks
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    is ur car ABS working or not incase of emergency brake
    Jan 2009
    44
    57
    @asad1
    how I check.
    do i press brake hard or any other way?
    thanks
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    just press the brake hard at about 40.. you'll feel some out of the world vibrations and hear some metallic noise from the engine compartment. and your tyres WONT lock up no matter how hard or quick you push the brake.
    https://www.facebook.com/OsamaAbbasPhotography
