Results 1 to 12 of 12
Thread: problem in vitz
    manaskajn126's Avatar
    Jan 2007
    Abu Dhabi
    28
    260
    Default problem in vitz
    just bought a vitz 03 model...whenever i apply the brakes the steering trembles and the car does bubbling while it is smooth to drive otherwise until the brkaes r applied...wat could the prob be??
    DEAD EDIT: Moved to correct section
    saddal's Avatar
    Jun 2006
    86
    87
    get the brakes checked.
    doubletrouble's Avatar
    Mar 2005
    27
    1,574
    get the brakes bleeded
    chk for the brake pads....and also chk for the typre, should be aligned
    drug-s3x-money .....be careful: this is the kind of obsession that can render you utterly useless
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Bushings FAIL?
    https://www.facebook.com/OsamaAbbasPhotography
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    Rotors require polish
    Suggestions required
    asimrafique's Avatar
    Mar 2006
    44
    9
    the correct answer is: you need to replace the roters (Disc Breaks) not the shoes or cheaper way is to re-surface them. I have the same problem then i changed one by one and now it is going fine.
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    yeah rotor has lost its shape dont get it polished or tooled its useless better go for new..
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    Jan 2007
    Abu Dhabi
    28
    260
    aur yeh kitnay tak ka kharcha hay??
    Farhansa's Avatar
    Oct 2006
    8,715
    5
    84 Post(s)
    disc change karwao ya tool lagwa lo
    ahsanazeem's Avatar
    May 2006
    32
    18
    Just get the brake pads and shoes changed........zyada kharcha nai hai......u can get the Shoes for around 700 and the Pads for around 500 or 600......Depends on wut u go for....
    Besides that it has ABS.......so an ABS brake Paddle bounces back when it is applied in an emergency........may be u have'nt used an ABS b4 and u felt this cuz of that.......
    but its better not to compromise on brakes and get them thoroughly checked
    feezan1985's Avatar
    Nov 2008
    Rawalpindi
    26
    15
    its abs and it works this way
  12. #12
    feezan1985's Avatar
    Nov 2008
    Rawalpindi
    26
    15
