just bought a vitz 03 model...whenever i apply the brakes the steering trembles and the car does bubbling while it is smooth to drive otherwise until the brkaes r applied...wat could the prob be??
get the brakes checked.
get the brakes bleeded
chk for the brake pads....and also chk for the typre, should be aligned
Bushings FAIL?
Rotors require polish
the correct answer is: you need to replace the roters (Disc Breaks) not the shoes or cheaper way is to re-surface them. I have the same problem then i changed one by one and now it is going fine.
yeah rotor has lost its shape dont get it polished or tooled its useless better go for new..
aur yeh kitnay tak ka kharcha hay??
disc change karwao ya tool lagwa lo
Just get the brake pads and shoes changed........zyada kharcha nai hai......u can get the Shoes for around 700 and the Pads for around 500 or 600......Depends on wut u go for....Besides that it has ABS.......so an ABS brake Paddle bounces back when it is applied in an emergency........may be u have'nt used an ABS b4 and u felt this cuz of that.......but its better not to compromise on brakes and get them thoroughly checked
its abs and it works this way
