Results 1 to 5 of 5
Thread: Vitz Problem
    asimrafique's Avatar
    Mar 2006
    44
    9
    Default Vitz Problem
    I have 1999 Vitz 72K running. it's average is comming down in city to 8-9 l/km and also it knocks when throttle in 2nd gear. can some one guid me for best tunning where to go in Rawalpindi? and what is normal aveage in same model with a/c? in City?
    DEAD EDIT: Moved to correct section
    doubletrouble's Avatar
    Mar 2005
    27
    1,574
    mine used to give around 12 on a/c within city...had the same 99 model
    get the car tuned...that would solve the problem
    i normaly do it from ENERCON, its near melody food park..islamabad
    drug-s3x-money .....be careful: this is the kind of obsession that can render you utterly useless
    Site Banned Follow
    malik593's Avatar
    Jan 2008
    Beijing
    26
    2,855
    have u removed ur catalytic converter its the problem of catalytic converter get it removed from rawal,isb,capital or gt
    predator101's Avatar
    Dec 2008
    28
    21
    Don't ever get your catalytic converter removed!!!
    It's dangerous for the environment and you too...
    Just get it tuned, and get the ECU caliberated
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    Put some Hi octane in your car and run it in low revs for few days rest get throttle cleaned,Map sensor cleaned and replace the plugs and Oils if due InshaAllah it will improve..Also get the tyres pressure @ 28 30psi
    @mileage im getting 12kms on N/A setup and cat is in the pipes
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
