Results 1 to 8 of 8
Thread: Advise me about VITZ ECU reset
    saqib1's Avatar
    Aug 2008
    43
    48
    Default Advise me about VITZ ECU reset
    Dear Pakwheelers !
    I was facing bad caverage, loss of power and decreased pick in my vitz 2005 from quite some time.
    In the first instance i got the engine oil changed as well as oil filter and replaced air filter
    with genuine Denso one but felt no improvement.
    Yesterday I made the throttle body washed with cleaning fluid and changed the plugs with original
    Denso iridium tipped. I also got its Cat Converter removed and O2 sencer cleaned. After that I
    noticed the following changes :
    a) The pick has somewhat improved.
    b) There is an increase in engine sound .Increase in RPM is also quite noticeable.
    c) The acceleration pedal feel a bit soft.
    d) Improvement in average has not yet been calculated.
    To solve the problem of elevated RPM my mechanic has advised me to reset its ECU by unplugging
    battery's -ve terminal for 1 or 2 minute before plugging it againn.
    I request your advice regarding :
    1. Is this the correct way to reset ECU.
    2. Will the reset have any negative effects on engine performance?
    3. How else can i further increase the pick and average?
    Thanx
    DEAD EDIT: Moved to correct section
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    Do it. That's a normal procedure
    Suggestions required
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    well no tension do it it advised to tht even after every oil change
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    noman111's Avatar
    Nov 2008
    Quetta
    44
    88
    DEAD EDIT: Avoid such comments to the user who wanna ask something serious. Comments like these would lead to a disaster
    ahmedshaikhani's Avatar
    Feb 2009
    26
    1,120
    2 Thread(s)
    Get your car tuned on computer from toyota or any other. Your ecu needs to get set.
    4G13 SOHC Turbocharged. 4G93T Mivec Turbo with GT30R, Emanage Ultimate 1.5Bar, 353Whp. 1JZ-GTE, Single Turbo, 4G63T 6th Gen FWD. Team DEKA.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    and yeah, after you reset, take your car out for a good drive of about 15 to 20 kilometers, so that the computer can 're-learn' the parameters and inputs from various sensors.
    https://www.facebook.com/OsamaAbbasPhotography
    saqib1's Avatar
    Aug 2008
    43
    48
    Thanx all who positively replied.
    I have made the ECU reset as advised. The RPM has considerably dropped to normal limitz and engine noise has reduced. Average has yet to be calculated.
    One thing more that after the CAT removal , can the identical readings of both the O2 sensers sent to ECU make it puzzled and resultantly effect engine performance??
    Thanx
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    No, not really. You'll be fine without it. All you needed to do is reset the ECU.
