Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: vitz AC??
    kahmr78's Avatar
    Aug 2006
    Rawalpindi
    38
    317
    Default vitz AC??
    is vitz AC supposed to be unlike Toyota AC?? cuz mine is abit sluggish on startup and idle positions... but it starts kicking in and taking off once the car starts moving and then it gets quite better once the car is on-roll i.e. long drives / intercity-long-drives .. but as soon as u stop or go idle.. the AC starts detoriorating the conditioning ... is it supposed to be like that.. or do i need to get my AC belt checked??
    i went to toyota rawal... and they thoroughly checked my AC and said its perfect and needs no maintainence... mine has done 60k odo ..
    my guess is maybe the AC belt needs tightening or replacement? or maybe generator needs soem fixing ??
    i recently got my car checked for 60k odo .. heres the link
    https://www.pakwheels.com/forumreply...mID!10~pw.html
    pls suggest...
    take tym in giving.. lyf's 2 short 2b selfish
    rusty_racer94's Avatar
    Aug 2007
    Clifden.Co.Galway
    22
    8,808
    I think thats because of a small engine
    This dog, is dog, a dog, good dog, way dog, to dog, keep dog, an dog, idiot dog, busy dog, for dog, 30 dog, seconds dog! ... Now read without the word dog.
    hashimsiddiq's Avatar
    Aug 2006
    31
    3,237
    does ur car vibrate when its ideling? if it vibrates then it need tuning or plug change. when have u last changed ur plugs and cleaned throttle body? do u have CNG in it?
    Ac requires a certain level of rpm to operate and if its not getting the required rpms then AC trips at ideling and stops working..
    2559922's Avatar
    Jun 2009
    calgary
    32
    1,024
    your compressor has become weak. keep using it until it needs replacement
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    No AC works best at idle
    Suggestions required
    kahmr78's Avatar
    Aug 2006
    Rawalpindi
    38
    317
    @ rusty .. ahh yea true but toyota's AC's r generally quite responsive.. no?
    yo @hashim.. i updated my orignal post with a link.. check that out aswell pls.. so i guess watever u said has been taken care of already.. still AC not working best on idle... (mind u its quite good when car is not idle) though still not equalent to corolla
    and no car does not viberate.. and i dont have CNG
    @panicslayer.. ahh wish mine does aswell .. inshaAllah i'll get it tuned up with you guy's guiadence
    @ 2599* .. i wish and hope thats not the case.. ur scaring me man lol
    OptimusSS's Avatar
    Oct 2007
    26
    2,247
    @kahmr78
    its normal for all cars, including vitz. however if it seriously goes dowm on idel then there may be a prb, if its just a minor change then its normal.
    saraab14's Avatar
    Nov 2008
    36
    164
    i am soory to say but no body gave you the solution..
    There are couple of thing sthat needs to be done.
    You A/C Works dine when you car is in motion and poor when idle...If So..
    Then tell me if for how long it trips, in idle....
    LEt me give you a proper solution.
    Try the following:
    When the outside temperature is hot, and at idle your A/C is not working, turn on your A/c, and wash the radiator thoroughly and when you are sure that radiator fins are all wet, get inside the car and check for cooling ....check the difference...
    If this works..tell me i"ll give the solution.
    Regards
    Aug 2007
    Clifden.Co.Galway
    22
    8,808
    MAn you have created 3 different topics for 3 small questions.......Why dont you just stick to one topic??
    saraab14's Avatar
    Nov 2008
    36
    164
    why don;t you tell me how to trouble shoot...
    Let's see what can you come up with...
    It should be good...other wise try to understand the problem...
    Nov 2008
    35
    10,044
    10 Post(s)
    @saraab
    If radiator fins are wet and AC works fine. Then what wud be the solution?
  12. #12
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Quote Originally Posted by saraab14
    Try the following:
    Regards
    i like your style (Y) you are genuinely "troubleshooting" his car,.. only 6 posts but DAYYUM this was a class A reply. keep it up.
  13. #13
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Saraab, what you've said, happens with my car.When the AC is not cooling properly at idle, spraying some water at the radiator and the condensor makes it cool much better.
    https://www.facebook.com/OsamaAbbasPhotography
  14. #14
    saraab14's Avatar
    Nov 2008
    36
    164
    easy.. For all cars....
    Just go to your mechanic... have your radiator removed..There is a general term used by mechanics calledc"chemical wash". Actually what they do is they make a very dilute solution of acid,any readily available,like toilet cleaing solution.
    After removing the radiator ...they whah it with that solution and BINGO.
    Also condensor needs to be cleaned in the same manner, except that its not removed other wise refrigerent will be lost.
    theory is that Radiator fins get clogged with dust and moisture hardens it. hence heat transfer area is reduced. Thus less effective cooling. Simple.
    Remember have this done only by and expert..
    I,by the way, do it myself.
  15. #15
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Oh, well my radiator is quite good, just had it serviced and stuff, fins are good.. what I'm going to do is install a better fan, and see.
  16. #16
    saraab14's Avatar
    Nov 2008
    36
    164
    and which do you have?
  17. #17
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    you are VERY lucky if TOYOTA people said you don't need to change anything.
    as for the a/c, atiq bhai has the same problem with his. got it serviced, no improvement. got a filter out of the dashboard panel changed, still nothing. strange thing is he says it was working perfectly fine in Carachi last year.
  18. #18
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Seems like a weak compressor but this can also be service issue.
    What you can do is get your whole a/c System serviced they will take apart everything clean em and fit them back and replace any faulty things.
    Kharcha will be around 2000 Rs.
    Speed costs money, how fast can you afford to go.
  19. #19
    saraab14's Avatar
    Nov 2008
    36
    164
    No offence..
    But please tell me one thing..
    If it work fines while moving around and not while idle..then how come A/c needs servicing?
    for such sort of problems...The very first thing is to check for rediator,condensor surface.If clean,fine ..
    If not then thats the problem.
    In this case his fins are clean..as he say....so This must be a compressor related issue...A Weak compressor...When moving compressor rpm increases, it wworks much harder and you feel the difference. Since Vitx are 6-7 years old ...this could be the root cause..
    But anywwaay before spending 20,000 on new compressor ..its wise to have you A/c Unit thoroughly serviced.
  20. #20
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    service didn't make a difference na
