Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 42
Thread: vitz AC??
    kahmr78's Avatar
    Aug 2006
    Rawalpindi
    38
    317
    Default vitz AC??
    is vitz AC supposed to be unlike Toyota AC?? cuz mine is abit sluggish on startup and idle positions... but it starts kicking in and taking off once the car starts moving and then it gets quite better once the car is on-roll i.e. long drives / intercity-long-drives .. but as soon as u stop or go idle.. the AC starts detoriorating the conditioning ... is it supposed to be like that.. or do i need to get my AC belt checked??
    i went to toyota rawal... and they thoroughly checked my AC and said its perfect and needs no maintainence... mine has done 60k odo ..
    my guess is maybe the AC belt needs tightening or replacement? or maybe generator needs soem fixing ??
    i recently got my car checked for 60k odo .. heres the link
    https://www.pakwheels.com/forumreply...mID!10~pw.html
    pls suggest...
    take tym in giving.. lyf's 2 short 2b selfish
  2. #21
    hussam_tariq's Avatar
    Mar 2007
    28
    129
    As we are discussings the AC probs i wana be a little off from kahmr78 bhais topic and just wana ask if there is sum problem wid every Lianas AC or is it just mine ?? The AC is sumwat ****, the fan speed is **** slow and the cooling is real pathetic... Sory kahmr bhai just wanted to ask my sumwat similar prob in your post... Hope sum1 does reply me as well.... Looking forward anxiously...
    Homer: Weaseling out of things is important to learn. It's what separates us from the animals ... except the weasel.
  3. #22
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Servicing some time can reveal problems for instance maybe the dryer bottle is chocked or the expansion valve needs to be changed.
    And you can clean the condenser from outside but for cleaning evaporator you have to open up the inside box.
    So servicing improves cooling.
    BTW try not to use the fresh air option in the car its better to open up window than using fresh air.
    If you are a frequent fresh air user than your evaporator needs more frequent service.
    Hussam, Liana's a/c works fine you need to get your A/C checked. How old is your Liana? and whats the mileage?
    Speed costs money, how fast can you afford to go.
  4. #23
    whyboysfail's Avatar
    Jan 2008
    30
    519
    coz of small engine ..ac works best on 1300cc or above
  5. #24
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Actually this small engine theory is fine but if your a/c is in good condition than it works fine
    I got old 86 charade with 1000cc engine and my a/c is great.
    What happens is the bigger the engine the bigger the compressor and the better the handeling power of engine of A/C.
    But if you install Senden (Original) compressor with good condensor and your car dont have overheating problem you will forget 1300CC cars a/c :p
  6. #25
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    the most chilling a/c in small cars that i've come across till today is the one in an FX dad borrowed from someone when Corolla met an accident almost ten years ago. yes, as you can imagine, it was installed later.
  7. #26
    Vaqas1's Avatar
    Nov 2004
    5,267
    6
    49 Post(s)
    Below 1000CC problem is the Engine Heat bcoz of small body stracture you can not install 2 fans so some lucky people are running a/c on 800cc but most will face problems.
  8. #27
    ahmedshaikhani's Avatar
    Feb 2009
    26
    1,120
    2 Thread(s)
    I had the similar problem last week. But I ignored it, than later on ac didn't even cool when car was running. I went to the ac shop and got my ac checked. It has some leakages. Problem got resolved and now its working perfect.
    4G13 SOHC Turbocharged. 4G93T Mivec Turbo with GT30R, Emanage Ultimate 1.5Bar, 353Whp. 1JZ-GTE, Single Turbo, 4G63T 6th Gen FWD. Team DEKA.
  9. #28
    Mar 2007
    28
    129
    @ Vaqas1
    Sir my liana is 2006 model and its around 42k till now but i think i do need 2 get my ac checked.... Can u recommend sum1 in ISB please?? And thank u soo much for the reply
  10. #29
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    go to Mr. Rehan in G-8. his number is 03315236812. give my reference as Saqib, the one who got new compressor in grey Corolla `97. if he still doesn't recall, say m Rohail's friend. slightly expensive but sensible. o! i've yet to take Vitz to him.
  11. #30
    saraab14's Avatar
    Nov 2008
    36
    164
    Liana guy...
    tell me you problem in detail..
  12. #31
    Mar 2007
    28
    129
    @ VAJIH102
    Sir thanks a lot, i will be visiting this guy in g8 v.soon.
    @ saraab14
    Sir my liana is 2006 and the milage is 42K but the AC is not upto the mark, dunno y but the throw is real low and the air is not that cold either.. Needs a looooooong trip 2 cool down that 2 when all of the windows are shaded...
  13. #32
    REDZDEVIL's Avatar
    Jul 2008
    28
    3,489
    Well... Wen I got my Vitz da Duct Pipe (nt sure wats da technical word fr it) wznt properly installed I git it chcked N my A/C works fine now...!
  14. #33
    saraab14's Avatar
    Nov 2008
    36
    164
    start a new session as " LIANA A/C Help" and i'll correspond there...will solve your problem,INSHALLAH
  15. #34
    wasif111's Avatar
    Apr 2009
    Dubai
    35
    1,843
    26 Post(s)
    bro its common problem with 1000cc car... there is no problem with A.C
    Wasif Qayyum / Emaar Business Park, Building no.4, Office 505, Sheikh Zayed Road Dubai, U.A.E
  16. #35
    Proverbial_Slang's Avatar
    May 2005
    3,906
    29 Post(s)
    I have seen no issues with Liana A/C yet. I rate it as one of the best in the market.
    Death is not the greatest loss in life. The greatest loss is what dies inside us while we live.
  17. #36
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    hussam, let me know votever happens. i do hope though that your problem gets solved here through saraab14
  18. #37
    naqviali's Avatar
    Oct 2006
    Quetta
    45
    40
    2 Post(s)
    I too have this problem, got the service done, changed the ac filter, washed the radiator and my mechanic said the compressor is weak, doing all this without changing the compressor, the car is doing fine, however at some point I have to change the compressor! Having said that on CNG, the ac does not work for Vitz, that is the core, on petrol for me, it works fine...
  19. #38
    Retrograde's Avatar
    Dec 2004
    40
    2,439
    ok i am reviving this old thread, i have vitz 2002 auto (no CNG), and facing the same issue of practically no cooling at idle despite the fact that i got a new a/c compressor and condenser installed. How ever when the car starts moving then all is well
    Hail to the King Baeeeebay!!!!
  20. #39
    daniyalahmad's Avatar
    Jun 2009
    Select City
    8,435
    12 Post(s)
    2 Thread(s)
    ^ It could be due to a faulty condenser fan.
    It might not be able to push air through the condenser, thus the cooling decreases when the car is stationery, however once it gets moving the AC performance becomes good due to the passage of air through it.
    One of the most difficult things in the world is to know how to do something, and to watch without comment, somebody else do it incorrectly.
  21. #40
    Retrograde's Avatar
    Dec 2004
    40
    2,439
    guys, i have done a tweak that has increaed by A/C's cooling significantly. I have a vitz 1.0 2002 model and no CNG. As you know it has 1 cooling fan for both the radiator and a/c condenser at the back of the radiator but i think its not good enough due to our hot weather so a few days back i simplay had an additional consenser fan installed in front that turns on and off with the a/c and now i am a happy man!!!!!. It cost me just 3,000 and 30 mins for installation!!!!
