Page 3 of 3 FirstFirst 123
Results 41 to 42 of 42
Thread: vitz AC??
    kahmr78's Avatar
    Aug 2006
    Rawalpindi
    38
    317
    Default vitz AC??
    is vitz AC supposed to be unlike Toyota AC?? cuz mine is abit sluggish on startup and idle positions... but it starts kicking in and taking off once the car starts moving and then it gets quite better once the car is on-roll i.e. long drives / intercity-long-drives .. but as soon as u stop or go idle.. the AC starts detoriorating the conditioning ... is it supposed to be like that.. or do i need to get my AC belt checked??
    i went to toyota rawal... and they thoroughly checked my AC and said its perfect and needs no maintainence... mine has done 60k odo ..
    my guess is maybe the AC belt needs tightening or replacement? or maybe generator needs soem fixing ??
    i recently got my car checked for 60k odo .. heres the link
    https://www.pakwheels.com/forumreply...mID!10~pw.html
    pls suggest...
    take tym in giving.. lyf's 2 short 2b selfish
  2. #41
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,405
    131
    3992 Post(s)
    94 Thread(s)
    6
    the original fan is two speed, it should kick on to high speed once the A/C head pressure increases, its controlled by a sensor on the liquid line after the condenser.
    You should also check the relays, relay 1 is for positive supply to fan, relay 2 is for negative switching between full ground (high) and resistor ground (low), by default its always on low speed.
  3. #42
    MoizIrfan's Avatar
    Dec 2007
    Dubai
    26
    1,960
    106 Post(s)
    @saraab14
    how to service the condenser with acid without taking it off from the car as acid can harm the wiring and condenser's surrounding areas??????????
