Results 1 to 5 of 5
Thread: Vitz 2005 again. This time, its the engine oil!
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Default Vitz 2005 again. This time, its the engine oil!
    I searched around the forums and found Zic A+ to be a good option.
    Now, since I haven't been maintaining the car till now, I don't know what oil has it been run through the 60000 kilometers it has run. The engine is in a pretty good condition, I want to know if I can still start using an oil like Zic A+ in that engine?
    I need 5W-30 Oils and if you people can list the good brands they come in with that'd be very helpful!
    https://www.facebook.com/OsamaAbbasPhotography
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    ouch!
    aomair's Avatar
    Apr 2005
    576
    5W-30 is not recommended for daily run and Pakistani environment.
    10W-40 fits best for our environment and since you have newer engines, it suits the same too.
    ZIC and Castrol are good brands.
    Change of faces won't change anything in Pakistan. www.greenwood.pk
    Scorpion1983's Avatar
    May 2009
    33
    1,018
    Put Zic A in then change again after 2500 or 3000kms
    Lucky guy.... Allah is the gratest.....Seat belt saves life...
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Any idea as in where to buy Castrol within Lahore?
    And which one should I go for? Magnatec or GTX?
