Results 1 to 15 of 15
Thread: PICK OF VITz
    feika's Avatar
    May 2004
    42
    100
    Default PICK OF VITz
    I've got a '99 model, 2007 registered Vitz, done 50K, out of which only 4k were done on CNG. My problem is when I start the car in the morning or even after rest of say, 2-3 hours, it just doesn't pick with the A/c on!!!
    I have to switch off the A/c, have to constantly paddle the accelerator and even then the car goes like 5-10 miles an hour till such time that the engine gets a little warmer. But when I put the car in neutral, the engine runs perfectly.
    The car has recently been tuned with oil, plugs, points etc changed. Any one has any idea what could be the problem.
    Please post in correct section - MOD
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    your compressor needs to be looked at by a qualified mechanic i think.
    raqeeb3k's Avatar
    Jan 2009
    32
    122
    Valve Problem...
    feika's Avatar
    May 2004
    42
    100
    Thank you guys, @Storm: If it's the compressor then it should effect the cooling as well but the cooling is just fine @raqeeb3k: Are you sure it's a valve problem because once the car gets the momentum it just runs normal.
    TM
    TM is offline
    TM's Avatar
    Apr 2004
    43
    2,715
    29 Post(s)
    Never had the chance of keeping a Vitz so do not know much about this car. But would like to know, if you are facing the same problem even when the car is driven on petrol? Or it only happens on CNG?
    "Never drive faster than your Guardian Angel can fly."
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    This problem is affiliated with most of the vitz
    Suggestions required
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    i'm such an idiot, i misread your post i thought you wrote that your AC trips,.. sorry sorry sorry.
    this problem you are facing most liekly has to do with your auto choke/idle, throttle position sensor, or airflow sensor. further than this I'd not like to speculate what exactly it could be and would suggest you take it to a qualified mechanic
    accord7362's Avatar
    Jun 2008
    44
    8,290
    6
    197 Post(s)
    34 Thread(s)
    am a strong believer that CNG & Auto transmission are not a good friends.
    Some people claim that they are doing fine with AUTO/CNG combination but the point is as soon as you put your car on the lethal injections of CNG its get in to the “slow death zone” and eventually you will get different type of problems so may be this problem is related to CNG directly or indirectly.
    I never drove vitz but heard that it has very good pick & it’s a good car.
    http://www.pakwheels.com/forums/members-member-rides/266031-accord7362s-merc-thanks-god-loved-ones-who-remember-me-prayers ,199119-thanks-god-2011-ford-edge-limited-awd-3-5-v6
    REDZDEVIL's Avatar
    Jul 2008
    28
    3,489
    Well a frnd wz havin a similar problem....!! He juz got his ride Tuned...!!
    n Nw he's satisfied wd da pick n everything...!!
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    i had this problem in my 1999 vitz and the cng guy said that its because of faulty advancer
    http://www.facebook.com/V8Rx8
    smrn's Avatar
    Jan 2007
    36
    209
    feika
    clean the MAF sensor just in case.
  12. #12
    sydahsan's Avatar
    Jan 2007
    31
    659
    i agree with panicslayer
  13. #13
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    How are the plugs you put in? Were they gapped correctly? and if it happens only on AC it could be the compressor as storm said..
    https://www.facebook.com/OsamaAbbasPhotography
  14. #14
    feika's Avatar
    May 2004
    42
    100
    Thank you guys for your kind words of advice. The car has got a great pick even with the A/c on but AFTER the engine gets some warm up. It only ran on CNG for 2,000 or so km before the first owner discontinued it and I never put it in CNG since I have taken the possession of the car.
    I guess I need to check it up with a good CNG mechanic and cut off the system altogether and then see what may be the problem.
    If it's the plugs or tuning, then the car would knock, or missing current but nothing of the sort happens. You start the car in the morning and it's just perfect, but the moment you switch on the A/c.................
  15. #15
    shirazkhan's Avatar
    Sep 2006
    27
    1,656
    2 Post(s)
    yar just in case clean the 02 sensor & MAF sensor they r responsible for the performence
    http://www.darsequran.com/ http://www.aswatalislam.net/
