Results 1 to 11 of 11
Thread: VITZ MISSING ON CNG AND PETROL
    pakion's Avatar
    Oct 2006
    35
    48
    Default VITZ MISSING ON CNG AND PETROL
    I have a
    Vitz
    2003 Model Last sunday i go to service station and wash my card engine and body.
    After that i feel the cars start missing. I switch off the Ac and Change from
    CNG
    to Petrol but still facing the same issue.
    When car standing in start mode its fine even i switch on AC,
    but when i gear the car from
    N
    to
    D
    its start missing on
    CNG
    and Petrol ,
    Yours urgent response in this regards is very value able for me.
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    reset ECU by removing -ve battery terminal for more than two minutes!
    http://www.facebook.com/V8Rx8
    sydahsan's Avatar
    Jan 2007
    31
    659
    Needs to be inspected by PakWheels' Mechanics !
    generallee's Avatar
    Jun 2008
    970
    6 Post(s)
    where are pakwheels mechanics?
    Jumpshare.com - Share and view over 250 file formats online (A venture from Pakistan)
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Open the the ignition coils, dry their contact spring with a cloth and check the rubber boots for any water or moisture..
    open the spark plugs, clean them with a tissue paper or sort of thing, dip their tips in petrol for like 2 to 5 mins.. let the petrol evaporate off the tips and put them back in, the ignition coils back on.
    clean the air filter box of any dirt / grease / moisture. Check if your air filter is dry or not, if it is not, let it dry.. meanwhile start your car and see how does it behave.. just get a new filter when you're at it..
    or before starting, you can wait for the air filter to dry out, and in the meanwhile, you can check all the connectors you can see in the engine bay.. check for any moisture / water in them.. open them one by one, check, clean / dry, connect them back.. their is a spray to clean these connectors, I don't remember the name.. WD-40 is good too but, you have to wait like 4 to 5 hours before you can connect them back..
    https://www.facebook.com/OsamaAbbasPhotography
    pakion's Avatar
    Oct 2006
    35
    48
    Were i found the ignition Coil Dear
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Where do your spark plugs go? the black things on the top of the plugs are the ignition coils..
    pakion's Avatar
    Oct 2006
    35
    48
    Ok i got it Could you please lets me know how can i open the Plugs becaue its very downside in the engine ,
    Do you tels me any proper tool to remove the Plugs.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    if you don't have a 16mm deep socket for the plugs, better get that done by a mechanic..
    guybwp's Avatar
    Jan 2011
    423
    16 Post(s)
    my car is missing both on petrol n cng..its daewoo racer...i recently changed its ecm as it was faulty but before changing it,it was just missing on cng n dat too just on startup n then car would go smooth but now after just changing the ecm with the right one car started missing...the mechanic ran it on diagnostic mode n it started missing....the plug wires been cleaned a month back n i dnt know any reason for them to b shorted all of a sudden..can anybody help me out
    ussi's Avatar
    Nov 2010
    Hyderabad
    27
    3,159
    35 Post(s)
    your emulator is gone
    Ministry of MAFIA!
