Results 1 to 10 of 10
Thread: Vitz 1KR-FE 1.0 liter engine
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Default Vitz 1KR-FE 1.0 liter engine
    I want to know that how is it timed? Does it have timing chain or that serpentine belt does that? If the serpentine belt goes bad, or slips, or breaks, will it be out of time? Well it will be if it doesn't have timing chains.. hence the question :p
    https://www.facebook.com/OsamaAbbasPhotography
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    vitz 2005 model 1000 cc 3-cylinder engine.. that is..
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    Number of cylinders 3 in-line
    Valve mechanism 12-valve DOHC VVT-i chain drive
    Fuel injection system Electronic fuel injection
    Displacement (cc) 998
    Maximum output (kW@rpm) 50/6000
    Maximum output (DIN hp@rpm) 68 DIN hp/6000
    Maximum torque (Nm@rpm) 93/3600
    Maximum output (DIN hp) 68
    Compression ratio 10.5:1
    Bore x stroke (mm x mm) 71.0 x84.0
    Engine code 1KR-FE
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    so, chain drive, means that the timing will not be messed up if the serpentine belt is gone, right?
    hash4u's Avatar
    May 2005
    38
    24,366
    18
    404 Post(s)
    13 Thread(s)
    13
    timing belt or chain has nothing to do with serpentine belt neither with timing
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    thanks.. had to confirm :p
    ahmed87's Avatar
    Nov 2007
    29
    87
    Can anyone tell which serpentine belt i should use in my vitz 06 , 3 cylinder 1kr-fe ?
    Unfortunately i couldn't find any information on it anywhere, I am currently using 100+20 belt, but it use to slips sometime specially while turning on the a/c, and i guess it also leads to stopping of the engine
    One thing more, Should I use Hi-octane in it or Premiere ? as it use to vibrate when fueled with premiere or with the mixture.
    Please help
    - Being on 2nd place just means FIRST LOSER !
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    well, you can goto your market and buy a Bando belt for like 3 to 400 rupees and see if it works.. if you get a good belt, it will work.. I have one belt, bought for 350 rupees, installed and running in a corolla, working fine and its been like 20000 kilometers now..
    recently i bought bando serpentine belt for this engine, it didn't work, slipping and squeaking bad.. and now I bought the original belt from a toyota authorised sales shop for 3400 rupees.. and its working fine.. so check the cheap bando belt before you buy the original one.. people say that it works.. didn't for me.. or maybe I just got a piece of **** belt... I'll try again next time..
    use hi-octane, mine feels much smoother on hi octane and no knocking what so ever..
    ahmed87's Avatar
    Nov 2007
    29
    87
    Well, i bought it and used it, it slips
    From where you get that original belt? Where is that authorized toyota sales shop in karachi?
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    where is the spare parts market in khi, I dont know
  11. 14-09-2016, 06:47 PM
    PakWheeler
