Results 1 to 17 of 17
Thread: Vitz 1KR-FE 1.0 liter engine again.
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Default Vitz 1KR-FE 1.0 liter engine again.
    It was idling low, vibrating and things. I thought it was because of the spark plugs, I changed the spark plugs and the air filter.. and its still doing that..engine is idling very low and whole car vibrates. What should be done? and from where.
    https://www.facebook.com/OsamaAbbasPhotography
    black's Avatar
    Aug 2006
    Rawalpindi
    30
    666
    4 Post(s)
    iz it on cng or petrol???
    bl@cK"Str33t BoY"
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Petrol.. petrol only..
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Is your mileage 50k plus?
    |||||||||||||||||||||||||||||| C2G - GARAGE | SHOP | TUNE +92 346 8776643 |||||||||||||||||||||||||||||||
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    yup, its between 60 to 70k..
    Don't have the CAT if you're going to suggest that bit.
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    If it is, are you still running the Cat?
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Have your valve clearances checked! There's no idle speed control and don't let anyone tell you to service your throttle body!
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    it has been removed..
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    hmm.. from where, the toyota dealership? Or is there someplace good?
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    and I forgot to tell, that it knocks as well time to time..
    yasir_01's Avatar
    May 2006
    others
    24
    4,507
    3 Post(s)
    2 Thread(s)
    vAlve ka problem hai shaid,,,
    * If electricity comes from electrons, does morality come from morons...!? * -Y[z]R-
  12. #12
    FLi_GTi's Avatar
    Jun 2005
    Ahead of you!
    38
    3,116
    Yup. Whats basically happened is that your car's had enough of the local brew. Have you're valve clearances adjusted as per specifications and she should be ok. I'd be glad to do it for you but you're rather far away.
    Tip. Whilst chugging around town, use the "S" mode and use High OC as much as you can. That'll eliminate knock.
  13. #13
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    hmm havent tested the S mode, using high OC eliminates any knocking though..
    What should I say to the mechanic in desi terms for the valves clearance?
  14. #14
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    uh. was having a brain **** at the moment.. so I'm going for a TAPPET SETTING
    From where in Lahore should I get that done people!
  15. #15
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    one more question, that even if I get the valves clearance checked, the tappets aren't adjustable, right? What to do if the valve clearance is not good?
    I need some more details before I goto Toyota stealership.. so that it would only cost me an arm and not a leg :p
  16. #16
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Fli gti? I need some help again.
    I've noticed today that it is missing as well, could it be because of the spark plug gaps?
  17. #17
    ahmedshaikhani's Avatar
    Feb 2009
    26
    1,120
    2 Thread(s)
    Problem is in your valve, if it would be plugs issue than the car would be missing. Check your valves.
    4G13 SOHC Turbocharged. 4G93T Mivec Turbo with GT30R, Emanage Ultimate 1.5Bar, 353Whp. 1JZ-GTE, Single Turbo, 4G63T 6th Gen FWD. Team DEKA.
  18. 14-09-2016, 06:47 PM
    PakWheeler
