Results 1 to 12 of 12
Thread: platz/vitz having timming cain or timming belt?
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    Default platz/vitz having timming cain or timming belt?
    plz help out in this regard?
    n whats its adjustment or replacement timeperiod or milage?
    SCHEHXAD
    Bughlol's Avatar
    Sep 2009
    Multan
    175
    2 Post(s)
    Its having timing chain and no service required !
    aabirgti's Avatar
    Nov 2005
    Islamabad/Walsall-UK
    31
    990
    Its timing chain 80% sure
    YES, i drive a Miata and NO, im not a hairdresser!!! Eunos Roadster S-limited, Bilstein, Torsen LSD, Borla Dual Exhaust, Nardi steering, Genuine red leather!
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    any1 who can telll with suriety plz k is it timming chain ]?
    SCHEHXAD
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Open the bonnet and have a look behind the pulleys,if there is a plastic cover,it means it has a timing belt and if there is a metallic cover then definitely it has a timing chain.
    Never loose hope in life,every step gives u something.
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    is this da criteria for knowing about its having timming chain or belt?
    SCHEHXAD
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    the vitz with the 1SZ-FE or 2NZ-FE has a single-stage silent timing chain, infact ALL Z-gen engines use timing chains instead of belts as they last longer.
    i'd suggest you get it inspected as soon as possible as all the vitz i have seen till now had had their milage tampered. consult your mechanic as to if it needs to be changed, but usually that shouldn't happen for at least 120-150,000 km (inspection every 60k)
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    dear r u confirm
    so nothing req?
    replacement or adjustment?
    SCHEHXAD
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    true. timing chain present and no timing belt. but there is at least one belt present in the engine either with the AC or alternator that needs to be changed.
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    thanks alot dear ....but even no adjustment of timming chain is req?
    is it so?
    SCHEHXAD
    Storm's Avatar
    Feb 2005
    Select City
    40,235
    9
    48 Post(s)
    5 Thread(s)
    Quote Originally Posted by schehxad
    dear r u confirm so nothing req? replacement or adjustment?
    yes, 100% confirmed, all you need is to get it inspected.
  12. #12
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    thanx alot dear~!
    SCHEHXAD
