Results 1 to 7 of 7
Thread: Vitz(manual gear) help needed(urgent)
    doni84's Avatar
    May 2005
    32
    58
    Default Vitz(manual gear) help needed(urgent)
    hello everbody
    yaar aj abhi thori dair phalay ek problem hoi with my car(vitz manual gear)
    hoa kuch asay mein gari chala raha tha phr mein ek jaga se gari ko u turn karnay laga tu os ke liye mujhe thora reverse karni pari tu jaisay he meine reverse ka gear lagaya aur pata nahi kia hoa.... may be meine speed kamdi aur clutch chora slowly tu ek ek choti se bilkol awaz se aye aur gari bhi bandnd hogaye
    aftr that whenever i have started my car tu jaisay he race se paon hata deta hon gari band horahi hai....petrol and cng dono pe....race de kar rakhon tu band nahi hota but missin horahi hai i ithnk.....but jaisay he race chor deta hon band hojati hai.....kindly koi bata sakta hai kia hoa hoa...regards
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    Saab se phahlay spark plug ki wire check kero kahein wo loose tou nahein hogayn,phir vacuum hoses check kero leakage ka liyee,aur air filter bhee check kero kahein wo chock tou nahi hogaya.
    Never loose hope in life,every step gives u something.
    hamad_ahsan's Avatar
    Dec 2005
    32
    203
    bro do check a pipe connected to your engine's head... it must be off its position... i have similar experience... not a problem in fact
    Bold and Dynamic... Second to None
    Dec 2005
    32
    203
    here is the pic.. m talking about the pipe marked in red...Vitzmanual gear help neededurgent -9778
    doni84's Avatar
    May 2005
    32
    58
    hamad_ahsan ap bilkol theek ho pipe connected to my engine's head nikal gaya tha..i saw in the morning i was so tensed but when opend my bonnet i saw that...n tum nay b bilkol yehe baat ki....thanks alot man...shukar kuch problem nahi hoi....
    Dec 2005
    32
    203
    it mostly happens due to pressure build up in that pipe.. and it releases it with white smoke... but this should not happen frequently... if do so... there must be some problem
    doni84's Avatar
    May 2005
    32
    58
    kis taran ki problem yaar????
