Results 1 to 5 of 5
Thread: Vitz on CNG... can we avoid venturi?
    hamad_ahsan's Avatar
    Dec 2005
    32
    203
    Default Vitz on CNG... can we avoid venturi?
    i am facing missing issues with my vitz both on CNG & Petrol. when venturi is removed, it runs fine on petrol. as per mechanic, this is due to increased gap introduced between MAF sensor and throttle body by venturi...
    My question is can we avoid venturi in order to inject CNG into throttle body???
    a frnd of mine removed venturi from my car and injected CNG directly in throttle body through the opening for blow off valve thus disconnecting it... missing problem was solved by engine started backfiring... and i had burnt air filters...
    is there any other efficient way to get CNG operational without using this venturi??
    Bold and Dynamic... Second to None
    123321123's Avatar
    Jun 2008
    85
    3 Post(s)
    This is not venturi issue.
    i also had the same issue but the problem was found in the CNG wiring.
    The Voltage was dropping for one of the piston-coil, changing the wires solved the issue and Alhmadulilah its running fine from that day onwards.
    Go to some real CNG mechanic and ask him to analyse the issue. (CNG wiring is put using petrol wiring, original one, so such issue causes missing both on Petrol and Gas)
    i hope this would help.
    Dec 2005
    32
    203
    thanks bro... i got venturi removed... inserted a nozzle in throttle body and now air cleaner is back on place... but issue still there... i took mechanic and car to ata wali autos... we changed all the coils, MAF sensor, advancer emulator etc there but of no use... all wiring is ok... now it seems like problem is with timing chain or something more deep... i'll continue tomorrow... wish me luck
    Spy3D's Avatar
    Nov 2007
    35
    40
    I also had missing issue on my Vitz but only on petrol, was running fine on CNG. It turned out that by fuel-pump motor has gotten weak, so i got it replace.. costed me around 6k
    Dec 2005
    32
    203
    Default Issue Resolved
    after trying all possible solutions... finally i replaced complete Head with a kabli one... and everything is running perfectly fine now... repairing head was expected to cost nearly 15k... but i got this head swap in 10K only
