Results 1 to 2 of 2
Thread: Vitz 2004-04 CNG Problem
    Spy3D's Avatar
    Nov 2007
    35
    40
    Default Vitz 2004-04 CNG Problem
    AOA,
    I got 2003 Toyota Vitz auto-transmission.. since yesterday i am having a problem with it on CNG but perfectly fine on Patrol.
    The problem is that when in low speed i leave the accelerator, the car vibrates a little turns and turns off ( like acceleration is low )
    So what can be causing this ? I repeat car is perfectly fine on patrol and this is happening only when i leave the accelerator at low speed or idle on CNG
    Thank you
    - Yunus
    shoodi's Avatar
    Nov 2006
    Rabwah
    36
    318
    CNG Settings .. Required .
Tags for this Thread
