Results 1 to 2 of 2
Thread: Feul consumpion problem with vitz
    DR.Faisal's Avatar
    Mar 2010
    29
    111
    Default Feul consumpion problem with vitz
    I have just bough a 2002 vitz 1300cc 2NZ-FE auo tranny..
    Its giving me 10 km/Litre .
    i want to increase the feul economy. what should i do..
    i have jst changed the engine oil nd transmission oil..
    can someone suggest me a good relieable mechanic for tuning nd regular check ups in Lahore...
    Your cooperaion will be highly appreciated
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    no need to go for any mechnaic untill and unless you are in some serious trouble as these rides does not require work quite often.
    Swap the Spark plugs,Go for Iridium or Platinum tips which are oe recomended for this motor.Reduse some extra weight if you using too wide tyres wth heavy alloys try to get lighter rims and get tyre size checked from Tyre size check calcultor.
    Get intake manifold cleaned and keep the air filter clean.
    Also take care of tyre pressure
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
